PIC Basic Code Understanding
Results 1 to 15 of 15
    Default LCD initialization problem
    Quote Originally Posted by malc-c View Post
    Using the attached image and the following code will better explain Henriks post with regards to using other ports
    DEFINE LCD_DREG  PORTB          ' LCD Data port
    DEFINE LCD_DBIT  0              ' starting Data bit (0 or 4)
    DEFINE LCD_EREG  PORTB          ' LCD Enable port
    DEFINE LCD_EBIT  5              '     Enable bit  (on EasyPIC 5 LCD)
    DEFINE LCD_RSREG PORTB          ' LCD Register Select port
    DEFINE LCD_RSBIT 4              '     Register Select bit   (on EasyPIC 5 LCD)
    DEFINE LCD_BITS  4              ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2              ' number of lines on LCD
    DEFINE LCD_COMMANDUS 2000       ' Command delay time in us
    DEFINE LCD_DATAUS 50            ' Data delay time in us
    You can then use the following to initialise the LCD
    LCDOUT $FE,1:FLAGS=0:PAUSE 250:LCDOUT $FE,1:PAUSE 250 ' Initialize LCD
    Hello Sir,
    I am doing same things and working fine but sometimes when i power on the controller LCD doesn't display anything or it may display some garbage characters.
    I am using pic 16f876A controller with crystal freq 10Mhz
    LCD controller - Samsung KS0066
    any suggestions are well comed...
    thanks in advance
    malc-c's Avatar
    malc-c Guest
    Occasionally I've experienced similar things after the initial re-programming. Resetting the PIC or power to my development board always works for me.
    Sep 2005
    Campbell, CA
    You often have to pause about a half second before you write anything to the LCD. The displays are slow to get "started". The quarter-second pause in the previous example may not be quite enough.
    Charles Linquist
  1. Making Program Code Space your playground...
  2. pic Basic Pro 2.50a & debug statement
    By Phil Moore in forum mel PIC BASIC Pro
    Last Post: - 17th March 2008, 10:41
  3. PIC BASIC or PIC BASIC PRO
    By kirkmans in forum USB
    Last Post: - 20th April 2007, 01:52
  4. Replies: 5
    Last Post: - 17th January 2006, 20:26
  5. Help with MPASM and PIC Basic
    By johngb in forum mel PIC BASIC Pro
    Last Post: - 21st February 2003, 14:07
