PIC Basic Code Understanding
Results 1 to 15 of 15
    May 2008
    Italy
    Define LCD registers and bits
    Define LCD_DREG PORTD
    Define LCD_DBIT 4
    Define LCD_RSREG PORTE
    Define LCD_RSBIT 0
    Define LCD_EREG PORTE
    Define LCD_EBIT 1
    Here you define the pin port that you will use to drive your LCD display.
    adval.highbyte = ADRESH ' Move HIGH byte of result to adval
    adval.lowbyte = ADRESL ' Move LOW byte of result to adval
    adval is a word variable (16 bits) and you load this variable in two steps copying two single bytes (adval.highbyte = ADRESH will transfer the high byte) and ( adval.lowbyte = ADRESL will transfer the low byte)
    Al.
    Feb 2010
    Default LCD config prob
    1 Define LCD_DREG PORTD
    2 Define LCD_DBIT 4
    3 Define LCD_RSREG PORTE
    4 Define LCD_RSBIT 0
    5 Define LCD_EREG PORTE
    6 Define LCD_EBIT 1
    -Correct me if I am wrong, I understand Line 1 & 2
    Line one means the LCD shold read from port D, Line 2 mean 4 bits
    Should be connected LCD i.e RD0, RD1, RD2 & RD3
    What I dont understand is line 3, 4, 5, 6. I am using pic16f876 & doest not hv pot D & E thats why I want to adapt this code
    1 DEFINE LCD_DREG PORTD
    2 DEFINE LCD_DBIT 4
    This tells PBP that you have your LCD data-bus connected to PortD and that it "starts" at bit 4 of that port. In other word, the databus is connected to PortD.4-7 which means you are using it in 4-bit mode and that you'll also need:
    DEFINE LCD_BITS 4
    To tell PBP that you're using it in 4bit mode.
    3 DEFINE LCD_RSREG PORTE
    4 DEFINE LCD_RSBIT 0
    This tells PBP that the RegisterSelect of the LCD is connected to PORTE.0
    5 DEFINE LCD_EREG PORTE
    6 DEFINE LCD_EBIT 1
    This tells PBP that the Enable of the LCD is connected to PORTE.1
    If your PIC doesn't have a PORTE then change the DEFINEs so it matches what you have - that's what they are there for.
    malc-c's Avatar
    malc-c Guest
    Using the attached image and the following code will better explain Henriks post with regards to using other ports
    DEFINE LCD_DREG  PORTB          ' LCD Data port
    DEFINE LCD_DBIT  0              ' starting Data bit (0 or 4)
    DEFINE LCD_EREG  PORTB          ' LCD Enable port
    DEFINE LCD_EBIT  5              '     Enable bit  (on EasyPIC 5 LCD)
    DEFINE LCD_RSREG PORTB          ' LCD Register Select port
    DEFINE LCD_RSBIT 4              '     Register Select bit   (on EasyPIC 5 LCD)
    DEFINE LCD_BITS  4              ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2              ' number of lines on LCD
    DEFINE LCD_COMMANDUS 2000       ' Command delay time in us
    DEFINE LCD_DATAUS 50            ' Data delay time in us
    You can then use the following to initialise the LCD
    LCDOUT $FE,1:FLAGS=0:PAUSE 250:LCDOUT $FE,1:PAUSE 250 ' Initialize LCD
    May 2009
    Montreal, QC, Canada
    Hi pr2don,
    I am just one week late but if you are still learning or trying to understand, this is where I learned how it works.
    http://iamsuhasm.wordpress.com/tutsproj/using-lcds/
    Mike
    Default LCD initialization problem
    Quote Originally Posted by malc-c View Post
    Hello Sir,
    I am doing same things and working fine but sometimes when i power on the controller LCD doesn't display anything or it may display some garbage characters.
    I am using pic 16f876A controller with crystal freq 10Mhz
    LCD controller - Samsung KS0066
    any suggestions are well comed...
    thanks in advance
    malc-c's Avatar
    malc-c Guest
    Occasionally I've experienced similar things after the initial re-programming. Resetting the PIC or power to my development board always works for me.
    Sep 2005
    Campbell, CA
    You often have to pause about a half second before you write anything to the LCD. The displays are slow to get "started". The quarter-second pause in the previous example may not be quite enough.
    Charles Linquist
  1. Making Program Code Space your playground...
  2. pic Basic Pro 2.50a & debug statement
    By Phil Moore in forum mel PIC BASIC Pro
    Last Post: - 17th March 2008, 10:41
  3. PIC BASIC or PIC BASIC PRO
    By kirkmans in forum USB
    Last Post: - 20th April 2007, 01:52
  4. Replies: 5
    Last Post: - 17th January 2006, 20:26
  5. Help with MPASM and PIC Basic
    By johngb in forum mel PIC BASIC Pro
    Last Post: - 21st February 2003, 14:07
