At the end of PC download (Angel.bas) it puts out 255 on all
How many bytes you need to tx?
This piece of code is not working properly, since the delay due to the instructions to be executed plus the pause will surely make you loose Tx data.
Think about to tx the whole packet in one go using array.Code:NEXTSTEP: debugin[#b1,#b2] 'Read input i2cwrite dapin,clpin,cont,addr,[b1,b2] 'Store in eeprom pause 10 'Wait between writes addr=addr+2 'Next eeprom loc if b2 <> $FF then nextstep 'FF means end of data
Replace pause 600 with For A0=1 to 120 :Pause 5:Next A0
Al.
I'm sending a varible amount of bytes, so far have lost none. The pause 600 is up where I read from eeprom. There's a pause 10 in interrupt routine to give time to write to eeprom. Everything works but doesn't seem to want to exit interrupt routine.
Because you have a problem with the timing in serial TX/RX.(as mentioned in post#14)Everything works but doesn't seem to want to exit interrupt routine.
Use a timeout to exit from DEBUGIN because you get stack there.
Al.
Shouldn't it exit when b2=$FF? I send a $FF at the end of all the data I want sent.
That's the way I understand, but I've been wrong alot of times.(As my wife says) If not I'll sure put in a timeout. Thanks.
Put in the timeout and works perfectly. Thanks to all that helped.
Mike
