ASM code
Results 1 to 21 of 21
Thread: ASM code
    Nov 2007
    South-West of Australia. A small town called Denmark. 'Where the forest meets the sea.'
    Default ASM code
    Help please.
    The PIC is an 18F8772 on a Futulec board (so hopefully the wiring is correct).
    I'm trying to use assembler to make the MCU produce two pulse streams for a set number of pulses:
    1. I use TIMER0 and TIMER1 for the inter-pulse delays.
    2. A simple 'count down' for the pulse duration.
    3. A counter that holds the numer of pulses to be generated, this is decremented - and when the counter hits zero - the routine should end.
    The code works OK - BUT! keeps 're-running.' i.e it puts out the required number of pulses, pauses for a bit and then does it all over again.
    Debugging with an ICD2 shows all the SFRs changing properly and the code ending after the requisite number of pulses - but when running normally it just keeps looping.
    The last few lines of ASM code is
    Main_loop:                   ; Check if X_steps_lb is zero			tstfsz	X_steps_lb   ; Test, skip next if equal
    	goto	Main_loop    ; More steps to do, so loop
    	bcf	INTCON,7    ; Disable all high priority interrupts
    	bcf	INTCON,6    ; Disable all low priority interrupts
    	bcf	T0CON,7	    ; Timer0 off
    	bcf	T1CON,0     ; Timer1 off
    I've not posted all the code because I don't think anyone would trawl through it.
    The CONFIG settings are:
                                               ;  Configuration bits
                 CONFIG  OSC = HSPLL         ; Run at 4X speed
                 CONFIG  CP0=OFF              ; Disable code protect
                 CONFIG  PWRT = OFF         ; Powerup off so DEBUG works
                 CONFIG  WDT=OFF             ; WDT off
                 CONFIG  LVP = OFF            ; LVP off
                 CONFIG  WAIT = OFF          ; External bus data wait disabled
    The re-set on MLCR is OK. The IDE is MPLAB. Anyone got any ideas?
    Regards Bill Legge
    END_LOOP:
           GOTO END_LOOP
    Once it hits END_LOOP it will stay there forever, This is sorta what PBP's END does.. I think//
    Nov 2007
    Default ASM code
    Dave,
    Thanks - I've just tried that and it works fine - the first time in 2 days that I have managed to get the code to output the correct number of pulses.
    However, I presume that when I incorporate the .asm code inside PBP the loop will prevent the .asm from ever finishing?
    ; lots of my asm code goes here
    End_loop:
    goto End_loop
    Any other ideas please? What on earth is making the PIC ignore all the 'end stuff' instructions?
    Regards Bill Legge
    END ' THE PBP TYPE
    When you jump out of the ASM routine and go back to PBP the END command should do what you want.
    Nov 2007
    Default ASM code
    Dave,
    Thanks for your support and interest.
    Having got it to work using the 'end-loop' process you suggested, I had a further play-around with the interrupts - and made it work!
    I added the code:
    bcf  RCON,7    ; Clear IPEN=0, disable priority interrupts
    And now all is OK.
    If anyone is interested in the code I'm happy to put it up here. The routine uses ASM to:
    1. Drive 2 stepper motors at the same time.
    2. Main purpose is to get diagonal moves on an XY plotter
    3. The asm code is passed parameters by PBP:
    a. X steps to be done
    b. Y steps to be done
    c. X inter-pulse delay
    d. Y inter-pulse delay
    4. Code has yet to be 'polished' and oly works with byte size parameters.
    Next is changing to accept WORD size parameters.
    Once again - thanks for your help.
    Regards Bill Legge
    Quote Originally Posted by Bill Legge View Post
    4. Code has yet to be 'polished' and only works with byte size parameters.
    Hi Bill,
    I would like to see it,
    Thank You.
    JS
    I added the code:
    And now all is OK.
    I have my doubts about that.
    IPEN defaults to 0 on Power-Up/Reset.
    So unless you have another RCON statement in your program that already changed it to 1, that statement will have no effect.
    Nov 2007
    Default ASM code
    Darryl & Joe
    Thanks for your comment - yes I do have code that sets RCON,7 (IPEN)
    to enable priority levels on interrupts.
    I've made an XY plotter/scanner using stepper motors and cheap Chinese linear bearings (about $10 each!). Only got the 'movement/plot bit' done so far and will add the scan later (Paralax Line Scan module).
    I went to assembler so that I could drive X and Y motors at the same time to get diagonal moves. This bit of the code works like:
    1. In PBP set the X_steps (Nx) and Y_steps (Ny)
    2. In PBP work out the periods of the pulses (Px znd Py) so that the time to make the X/Y moves are the same T(move) = Nx.Px = Ny.Py
    3. Send the variables to the ASM code
    4. Use Timer0 to interrupt (high priority) for Px
    5. Use Timer1 to interrupt for Py
    6. Decrament Nx whenever an X pulse is sent and halt at zero
    7. Stop and return to PBP
    It's the 'stopping' that took me two days to sort out and the guilty party was the IPEN bit - and an inexperienced asm programmer!
    Happy to post the code - sorry - I've used TABS and it looks terrible at the moment:
    ;	Filename: WL_Scanner_01                                                *
    ;	Date:	February 2010                                                   *
    ;	Function: Drive two stepper motors with timers/interrupts	        *
    ;	Files Required: P18F8722.INC                                           *
    	LIST P=18F8722		; Directive to define processor
    	#include <P18F8722.INC>	; Drocessor specific variable definitions
    	CONFIG	PWRT = OFF	; Power up timer off so DEBUG works
    ;	Variable definitions in data memory
    WREG_TEMP	equ	0x010		; Variable used for context saving
    STATUS_TEMP	equ	0x011		; Variable used for context saving
    BSR_TEMP	equ	0x012		; Variable used for context saving
    Count_pulse	equ	0x013		; Loop delay in 5 uS pulse to motor driver
    X_delay_lb	equ	0x014		; Inter-pulse delay for X axis, high byte
    X_delay_hb	equ	0x015		; Inter-pulse delay for X axis, low byte
    Y_delay_lb	equ	0x016		; Inter-pulse delay for Y axis, high byte
    Y_delay_hb	equ	0x017		; Inter-pulse delay for Y axis, low byte
    X_steps_lb	equ	0x018		; Number of steps to do on X axis
    X_steps_hb	equ	0x019		; Y steps not needed as Tx.Dx=Ty.Dy
    ;	Reset vector in program memory
    	ORG	0x0000
    	goto	Main_ASM		; Go to start of main code
    ;	High priority interrupt vector in program memory
    	ORG	0x0008
    	goto	High_int		; Go to high priority interrupt routine
    ;	Low priority interrupt vector and routine in program memory, when Timer1
    ;	overflows send out stepper drive pulse for Y axis on PORTD.3
    	ORG	0x0018
    	movff	STATUS,STATUS_TEMP	; save STATUS register
    	movff	WREG,WREG_TEMP	; save working register
    	movff	BSR,BSR_TEMP		; save BSR register
    	bcf	INTCON,7		; Disable all interrupts
    	bsf	PORTD,3		; High PORTD.3
    	call	Pulse_out		; Delay for 10 microseconds
    	bcf	PORTD,3		; High PORTD.3
    	bcf	PIR1,0			; Clear Timer1 interrupt flag
    	movff	Y_delay_hb,TMR1H	; Load Timer1 with Y_delay
    	movff	Y_delay_lb,TMR1L	; Load timer1 with Y_delay
    	movff	BSR_TEMP,BSR		; restore BSR register
    	movff	WREG_TEMP,WREG	; restore working register
    	movff	STATUS_TEMP,STATUS	; restore STATUS register
    	bsf	INTCON,7		; Enable interrupts
    	retfie
    ;	High priority interrupt routine, when Timer0 overflows, send out stepper
    ;	drive pulse for X axis on PORTD.0
    High_int:
    	bcf	INTCON,7		; Disable interrupte
    	bsf	PORTD,0		; High PORTD.0
    	call	Pulse_out		; Send 5uS pulse on PORTB.0
    	bcf	PORTD,0		; Low PORTD.0
    	bcf	INTCON,2		; Clear Timer0 interrupt flag
    	movff	X_delay_hb,TMR0H	; Load timer0 with X_delay
    	movff	X_delay_lb,TMR0L	; Load timer0 with X_delay
    	decf	X_steps_lb		; Decrement X_steps
    	retfie	1
    ;                               SUBROUTINES                                   *
    Pulse_out:			; Delay = 3.n + 7 [0.1 microseconds]
    	movlw	0xff		; Load w with n
    	movwf	Count_pulse	; Load Count with n
    Pulse_loop:
    	decfsz	Count_pulse	; Decrament the file Count
    	goto	Pulse_loop	; Loop if not zero
    ;                                  MAIN ASM                                   *
    Main_ASM:
    	clrf	TRISA			; PORTA is output
    	clrf	TRISB     		; PORTB is output
    	clrf	TRISC			; PORTC is output
    	clrf	TRISD     		; PORTD is output
    	clrf	TRISE			; PORTE is output
    	clrf	TRISF			; PORTF is output
    	clrf	TRISG			; PORTG is output
    	clrf	TRISH			; PORTH is output
    	clrf	TRISJ			; PORTJ is output
    	clrf	PORTA			; Clear PORTA
    	clrf	PORTB			; Clear PORTB
    	clrf	PORTC			; Clear PORTC
    	clrf	PORTD			; Clear PORTD
    	clrf	PORTE			; Clear PORTE
    	clrf	PORTF			; Clear PORTF
    	clrf	PORTG			; Clear PORTG
    	clrf	PORTH			; Clear PORTH
    	clrf	PORTJ			; Clear PORTJ
    	movlw	0x0f
    	movwf	ADCON1			; PORTA is digital I/O
    	movlw	0x07
    	movwf	CMCON			; Comparator off
    ; Set up interrupt conditions for Timer0 and Timer1
    	bsf	RCON,7			; Enable priority levels on interrupts,IPEN=1
    	bsf	INTCON,7		; Enable all high priority interrupts
    	bsf	INTCON,6		; Enable all low priority interrupts
    	bcf	INTCON,3		; Disable PORTB interrupts
    	bsf	INTCON2,2		; Make Timer0 overflow high priority
    	bcf	IPR1,0			; Make Timer1 overflow low priority
    	bsf	INTCON,5		; Enable Timer0 overflow flag
    	bsf	PIE1,0			; Enable Timer1 overflow flag
    ; Set up Timer0 conditions
    	bcf	T0CON,6		; Timer0 uses 16 bits
    	bcf	T0CON,5		; Timer0 uses internal osc
    	bcf	T0CON,4		; Timer0 count on rising edge og osc
    	bsf	T0CON,3		; Timer0 pre-scaler not assigned
    	clrf	TMR0L			; Zero the clock
    	clrf	TMR0H			; Zero the clock
    	bsf	T0CON,7		; Timer0 on
    ; Set up Timer1 conditions
    	bsf	T1CON,7		; Timer1 uses 16 bits
    	bcf	T1CON,1		; Timer1 uses internal osc
    	clrf	TMR1L			; Zero the clock
    	clrf	TMR1H			; Zero the clock
    	bsf	T1CON,0		; Timer1 on
    ;	Temp code to simmulate PBP input for the delays
    	movlw	0x00
    	movwf	X_delay_lb
    	movlw	0x00
    	movwf	X_delay_hb
    	movlw	0x00
    	movwf	Y_delay_lb
    	movlw	0x00
    	movwf	Y_delay_hb
    	movlw	0xff
    	movwf	X_steps_lb
    	movlw	0xff
    	movwf	X_steps_hb
    ;	End of Temp code
    ; Check if X_steps_lb=0 (decremented in high priority interrupt)
    ; If so, check X_steps_hb and if zero, end
    ; If not, decrement X_steps_hb, set X_steps_lb and go again
    Main_loop:
    	movff	X_steps_hb,PORTC
    	;comf	PORTC,1	; LEDS active low so invert
    	movff	X_steps_lb,PORTD
    	;comf	PORTD,1
    	tstfsz	X_steps_lb	; Test, skip next if zero
    	tstfsz	X_steps_hb	; Test, skip next if zero
    	goto	Re_load_lb
    	goto	All_done
    Re_load_lb:
    	decf	X_steps_hb,1	; Decrement hb and then carry to lb
    	setf	X_steps_lb	; Decremented hb, so load ff to lb
    	goto	Main_loop
    All_done:
    	end			; IPEN must be cleared or asm keeps running
    Regards Bill Legge
    Nov 2007
    Default ASM code
    And some more help please.
    I'm now having difficulty in putting the asm code into a PBP program:
    1. Running on a PIC18F8722.
    2. Low and high priority interrupts are used BUT IN THE ASM CODE ONLY.
    3. The action to be taken on interrupt is only in the ASM code.
    So far I have:
    1. Deleted the asm configs and done them in PBP
    2. Listed the variables like:
    WREG_TEMP       var byte    $20     System     ; Variable used for context saving
    STATUS_TEMP     var byte    Bank0   System     ; Variable used for context saving
    BSR_TEMP        var byte    Bank0   System	; Variable used for context saving
    Count_pulse     var byte    Bank0   System     ; Pulse duration = 3.n + 7
    X_delay_lb      var byte    Bank0   System     ; Subtracted from $ffff to get X delay
    X_delay_hb      var byte    Bank0   System     ; ..result loaded into Timer0_High and Timer0_Low
    Y_delay_lb      var byte    Bank0   System     ; Subtracted from $ffff to get Y delay
    Y_delay_hb      var byte    Bank0   System     ; ..result loaded into Timer1_High and Timer1_Low
    X_steps_lb      var byte    Bank0   System     ; Y steps not needed because different X/Y pulse
    X_steps_hb      var byte    Bank0   System     ; ..frequencies make Nx.Dx = Ny.Dy
    I have deleted (Should I have kept them?) these bits of the original ASM code:
    Should I use the instructions (although my interrupts occur in ASM only):
    DEFINE INTLHAND Label
    DEFINE INTHAND Label
    I have had a good read of the PBP handbook and DT's interrupt code and examples - but am still missing something?
    Regards Bill legge
    Sep 2005
    Campbell, CA
    Bill,
    I don't have time to give you a complete answer right now, but I believe you are making this too hard.
    If you use DT-Ints, you don't need to worry about saving/restoring the registers, or any ORGs. All of that is taken care of for you.
    All I can do right now is give you a snippet of some code that I have handy.
    This code has only high priority INTs, but low-priority INTS are done the same way.
    Go to Darrel's page and read about using his structure. It will really help you a lot.
    You will notice that the code snippet below has both PBP and ASM ints.
    MasterClock is defined as a BankA SYSTEM var so that PBP can access it.
    All the vars (including the ASM vars) are declared in PBP.
    '----------------------------------  End of basic assignment section ---------------------------------
            INCLUDE "DT_INTS-18.bas"         ; Base Interrupt System
            INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
                  INT_Handler    TMR0_INT,   SystemTimer,   ASM,  yes
                  INT_Handler    RX1_INT,    _GetCharPort1,    PBP,  yes
                  INT_Handler    RX2_INT,    _GetCharPort2,    PBP,  yes
                  INT_Handler    INT2_INT,   _GetXData,    PBP,  yes
    Goto OverInt
    '---[INT - interrupt handlers]-----------------------------------------------
    SystemTimer
             movff   0x0B,TMR0H  ;   10 msec with /16 prescaler
             movff   0xDC,TMR0L
             infsnz  MasterClock
             incf    MasterClock + 1
           INT_RETURN
    If no one else posts a better response, I'll send you more information tomorrow.
    Charles Linquist
    Nov 2007
    Default ASM code
    Charles,
    Thanks, I will have a go at doing the work with DT's interrupts - I'm pretty sure that you are correct.
    I wanted to use my own ASM to:
    1. Learn more about ASM
    2. Learn more about MPLAB and debugging.
    3. Learn how to glue ASM into PBP.
    The most useful things learnt over the last few days were:
    1. Debugging ASM with interrupts in it.
    2. After a quickish look at DT's interrupt code I think I may now be able to follow it.
    I'd much appreciate your input on getting the code on this thread to run in PBP. Despite playing with 'org' and so on, I keep getting lots of:
    overwrite previous address contents error
    Regards Bill Legge
    Regards Bill Legge
    You must be trying to set the configuration fuses more than once.
    In the PBP part of the code?
    In the ASM part?
    In the *.inc file?
    Sep 2005
    Campbell, CA
    Again -
    I think you would be FAR better off if you would just use Darrel's code as a starting point. Since you have two priorities, you need to put the following in your DEFINE block.
    DEFINE USE_LOWPRIORITY 1
    Then use Darrel's INCLUDE files as needed.
    INCLUDE "ReEnterPBP-18LP.bas" ; Include if using Low Pr. PBP INTS
    Then define your variables in PBP. If you have enough space, you can define all of them as BankA SYSTEM. If you don't, make certain that you define all the ones that you want to pass between PBP and ASM as bankA System
    The variables will be case-sensitive.
    Set up all timer prescalers, clock sources and triggering edges first.
    Now put in Darrel's interrupt control block -
    Change the labels as necessary.
    INT_LIST_L  macro  ; IntSource,        Label,  Type, ResetFlag?
               INT_Handler     PIC_YOUR_INT,        StepperControl, ASM,no
        INT_CREATE_L             ; Creates the Low Priority interrupt processor
    Goto OverInt
    (Put all your ASM ISR code here)
    @ INT_RETURN
    [Put all your PBP ISR code here]
    @ INT_RETURN
    Overint:
    (Clear INT flags)
    @ INT_ENABLE (name of INT)
    @ INT_ENABLE (name of other INT)
    NothingLoop:
     Goto NothingLoop  ; do nothing until you get an int.
    Hopefully, I haven't forgotten something. !
    Doing things this way will not only likely get you to a running program much faster, it will make it easier for others to give you the help you need. After all, this IS a PBP forum, not an ASM forum.
    Charles Linquist
    Hi Bill,
    I like to encourage everyone to learn assembly, and how to handle interrupts. Where would we be here if DT never learned assembly or interrupts...;o)
    Here's a simple modified version of what you had. Look at the changes I made VS your original. I could point to every single change,
    but it wouldn't help you learn much.
       #include "P18F8722.inc"  ; Drocessor specific variable definitions
      CBLOCK 0x0000  ; all in ACCESS RAM
        Count_pulse  ; Loop delay in 5 uS pulse to motor driver
        X_delay : 2  ; Inter-pulse delay for X axis, 2 bytes
        Y_delay : 2  ; Inter-pulse delay for Y axis, 2 bytes
        X_steps : 2  ; Number of steps to do on X axis, 2 bytes
      ENDC
       ORG    0x0000
    ;  All interrupts vector to here, Priorities disabled
       ORG    0x0008
       bra    Tmr_ints  ; Go to interrupt routine
    ;  Higher priority for Timer0 overflows, send out stepper
    Tmr_ints
       btfss  INTCON,TMR0IF    ; did Timer0 interrupt?
       bra    LowPri           ; no. branch to Timer1 int
       bsf    PORTD,0          ; yes. High PORTD.0
       bcf    PORTD,0          ; Low PORTD.0  (Timer1 interrupts around here)
       bcf    INTCON,TMR0IF    ; Clear Timer0 interrupt flag
       movff  X_delay+1,TMR0H  ; Load timer0 with X_delay high byte
       movff  X_delay,TMR0L    ; Load timer0 with X_delay low byte
       movf   X_steps,W        ; load WREG for compare after subtraction
       decf   X_steps,F        ; Decrement X_steps low byte
       cpfslt X_steps          ; if X_steps < WREG then jump over next decrement
       decf   X_steps+1        ; else, decrement high byte
    ;  Lower priority for Timer1 overflows, send out stepper
    ;  drive pulse for Y axis on PORTD.3
    LowPri
       btfss  PIR1,TMR1IF      ; Timer1 int pending?
       bra    IntExit          ; no. exit
       bcf    PIR1,TMR1IF      ; Clear Timer1 interrupt flag
       movff  Y_delay+1,TMR1H  ; Load Timer1 with Y_delay high byte
       movff  Y_delay,TMR1L    ; Load timer1 with Y_delay low byte
    IntExit
       retfie FAST             ; return & restore WREG, STATUS, BSR
    ;                               SUBROUTINES                                   *        *
    Pulse_out              ; Delay = 3.n + 7 [0.1 microseconds]
    Pulse_loop
    ;                                  MAIN ASM                                   *        *
    Main_ASM
       movlw  0x0f
       movlw  0x07
       bcf    RCON,7     ; disable priority levels on interrupts,IPEN=0
       bsf    INTCON,7   ; Enable all interrupts
       bsf    INTCON,6   ; Enable all peripheral interrupts
       bcf    INTCON2,2  ; Make Timer0 overflow low priority
       bsf    INTCON,5   ; Enable Timer0 overflow int
       bsf    PIE1,0     ; Enable Timer1 overflow int
       clrf   X_delay    ; this handles the low byte
       clrf   X_delay+1  ; this handles the high byte
       clrf   Y_delay
       clrf   Y_delay+1
       clrf   X_steps
       clrf   X_steps+1
    ;  End of Temp code
    Main_loop
       movff   X_steps+1,PORTC ; high byte to portc
       ;btg     PORTC,1         ; toggle RC1 (note: comf only works with whole 8-bit registers)
       movff   X_steps,PORTD   ; low byte to portd
       ;btg     PORTD,1         ; toggle RD1
       tstfsz  X_steps         ; Test, skip next if zero
       tstfsz  X_steps+1       ; Test, skip next if zero
       bra     Re_load_lb
       goto    All_done
    Re_load_lb
       decf    X_steps+1,F  ; Decrement hb and then carry to lb
       setf    X_steps      ; Decremented hb, so load ff to lb
       goto    Main_loop
    All_done
       bcf     INTCON,7      ; Clear GIE, disable ALL interrupts
       clrwdt
       sleep
       goto    $-2
    I think you're much better off putting both interrupts in the same handler, and just checking for which one caused the interrupt VS having a high pri interrupt your low pri, so you can use the auto restore for W, STATUS & BSR.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Nov 2007
    Default ASM code
    Bruce,
    Wow, what a lot of effort on your part - thanks very much. I will now re-fire up MPLAB and give it a detailed run.
    I do take note of CL's comments about this being a PICBASIC site but most entheuastic PBP users will want to experiment with ASM - for fun and speed?
    I know that every minuit I've spent on ASM in MPLAB had added greatly to my ability to write software in PBP.
    Perhaps there is space for an 'ASM' sub-section in this forum? I can understand that most newcomers will not be interested in this lower level stuff but it seems essential to make the most of PBP.
    We are in the middle of a heatwave here in West Australia - almost no rain for 3 months - too hot to do much outside so plenty of key-board time.
    Thanks again for your input.
    Regards Bill Legge
    Sep 2005
    Campbell, CA
    My goal was not to discourage ASM use (I use a lot of it myself), but only to point out that DT_INTs would make things easier for you. And since a lot of people on this forum are familiar with their use, a lot more people would be able to help you if you chose that route.
    Charles Linquist
    Nov 2007
    Default ASM code
    Charles & Bruce,
    Thanks for your help.
    Bruce: the code you provided works well and I've tested it in MPLAB with a variety of inputs and it's all OK.
    I have 'glued it into PBP and still can't get it to compile. The things I changed between the ASM_only and PBP_ASM are:
    1. Deleted the .asm CONFIGS because they come from my programmer.
    2. Deleted the .asm variable definitions in data memory, defined them in PBP, watched out for caes sensitivity and changed the .asm definitions to have a leading underscore (e.g. _X_steps).
    Nov 2007
    Default ASM code
    SORRY, I HIT THE WRONG BUTTON BEFORE I HAD COMPLETED THE POST
    PLEASE READ ON..........
    Charles & Bruce,
    I have 'glued' it into PBP and still can't get it to compile. The things I changed between the 'ASM only' and 'PBP_ASM' are:
    3. Took out the .asm PORT and TRIS lines because it's done in PBP.
    4. Took out the temp code to load the variables because they should come from PBP.
    5. Deleted the last 3 lines of code - not needed I presume?
    My, failed attempt to get the PBP to run looks like:
    ' File...... 8722 Scan_ASM_Test
    ' Purpose... Drive two steppers to achieve diagonal moves
    ' *                             INCLUDE & DEFINES                             *
    clear
    define OSC 40				' Use HSPLL during compilation
    ' *                                 VARIABLES                                 *
    X_steps         var word                     ' Steps to move, not reusable
    Count_pulse     var WORD    Bank0   System   ' Pulse duration = 3.n + 7
    X_delay         var WORD    Bank0   System
    Y_delay         var WORD    Bank0   System
    goto Start                                    ' Skip over ASM code
    ' *                              ASSEMBLER CODE                               *
    Run_ASM:
       ORG    0x0000
    ;  All interrupts vector to here in program memory, Priorities disabled
    ;  This is high priority only so wsave etc is automatic
       ORG    0x0008
    Tmr_ints
       call   Pulse_out        ; Call delay routine
       movff  _X_delay+1,TMR0H ; Load timer0 with _X_delay high byte
       movff  _X_delay,TMR0L   ; Load timer0 with _X_delay low byte
       decf   _X_steps,F       ; Decrement X_steps low byte
    LowPri
       movff  _Y_delay+1,TMR1H ; Load Timer1 with Y_delay high byte
       movff  _Y_delay,TMR1L   ; Load timer1 with Y_delay low byte
    IntExit
    ;                               SUBROUTINES                                   *        *
       movwf   _Count_pulse    ; Load Count with n
    Pulse_loop
       decfsz  _Count_pulse    ; Decrament the file Count
    ;                                  MAIN ASM                                   *        *
    Main_ASM
       bcf    RCON,7     ; Disable priority levels on interrupts,IPEN=0
    ; Temp code to simulate PBP input for the delays
    ; Removed - should come from PBP
    Main_loop
       movff   _X_steps+1,PORTJ ; Steps hi to PORTJ
       movff   _X_steps,PORTB   ; Steps lo to PORTB
       tstfsz  _X_steps         ; Test steps lo, skip next if zero
       tstfsz  _X_steps+1       ; Test steps hi, skip next if zero
       bra     Re_load_lb
       goto    All_done
    Re_load_lb
       decf    _X_steps+1,F    ; Decrement hb and then carry to lb
       setf    _X_steps        ; Decremented hb, so load ff to lb
       goto    Main_loop
    All_done
       clrwdt
    ' *                                INITIALISE                                 *
    Start:
    ADCON1	= %00001101           ' A0, A1 analog, rest digital
    CMCON	= %00000111           ' Comparators off, this frees up PORTF
    TRISA   = %00000000
    TRISB   = %00000000
    TRISC	= %00000000
    TRISD   = %00000000           ' D.0 is X drive. D.3 is Y drive
    TRISE   = %00000000           ' LEDs to display X_steps lo byte
    TRISF   = %00000000
    TRISG   = %00000000
    TRISH   = %00000000
    TRISJ   = %00000000           ' LEDs to display X_steps hi byte
    ' *                                   MAIN                                    *
        X_delay = $FFFF
        Y_delay = $FFFF
        X_steps = $FFFF
        Count_pulse = $FFFF
        gosub Run_ASM
        goto Main
    You used a .asm technique of defining a data address like:
    _X_delay : 2 ; Reserve two bytes in data memory
    If I have a variable in PBP like
    X_delay VAR WORD
    Will the WORD from PBP find it's way to the .asm?
    Charles L: I'm still going to do it using DT's interrupts
    Regards Bill Legge
    Hi Bill,
    Use DEFINE INTHAND and PBP will place a goto at 0x0008 to your int handler. If you have
    room in the access bank, it's a good idea to stick your variables there. Then you don't need
    to mess with banking in your .asm routines.
    clear
    DEFINE INTHAND Tmr_ints
    ' *                                 VARIABLES                                 *
    X_steps         var word    BankA   System   ' Steps to move, not reusable
    Count_pulse     var WORD    BankA   System   ' Pulse duration = 3.n + 7
    X_delay         var WORD    BankA   System
    Y_delay         var WORD    BankA   System
    Tmr_ints
       movff  X_delay+1,TMR0H  ; Load timer0 with _X_delay high byte
       movff  X_delay,TMR0L    ; Load timer0 with _X_delay low byte
    LowPri
    IntExit
    ;                               SUBROUTINES                                   *        *
    Pulse_loop
    ;                                  MAIN ASM                                   *        *
    _Main_ASM
    Main_loop
       movff   X_steps+1,PORTJ ; Steps hi to PORTJ
       movff   X_steps,PORTB   ; Steps lo to PORTB
       tstfsz  X_steps         ; Test steps lo, skip next if zero
       tstfsz  X_steps+1       ; Test steps hi, skip next if zero
       bra     Re_load_lb
       goto    All_done
    Re_load_lb
       goto    Main_loop
    All_done
       clrwdt
    ' *                                INITIALISE                                 *
    Start:
        TRISA   = %00000000
        TRISB   = %00000000
        TRISC   = %00000000
        TRISF   = %00000000
        TRISG   = %00000000
        TRISH   = %00000000
    ' *                                   MAIN                                    *
        X_delay = $FFFF
        Y_delay = $FFFF
        X_steps = $FFFF
        Count_pulse = $FFFF
        CALL Main_ASM
        goto Main
    X_delay VAR WORD
    Yes.
    You can also learn a lot about assembly by looking at code in MPLAB after you compile with
    PBP.
    -Bruce
    tech at rentron.com
    Nov 2007
    Default ASM code
    Bruce,
    That all works just great - thank you.
    I notice that you:
    1. Put an underscore (_) infront of the label that PBP jumps to (_Main_ASM).
    2. Not in front of the 'identifier' names of the variable shared between PBP and ASM.
    I thought the shared variables needed to:
    1. Be declared in PBP.
    2. Have an underscore when used in ASM.
    Page 194 in the BPB handbook? I'm obviously wrong because the code works?
    Regards Bill Legge
    Hi Bill,
    Variables declared as SYSTEM types don't have the underscore. See the section on RAM Usage in your manual.
    Look at the CALL command for the example with the underscore preceeding the label name.
    -Bruce
    tech at rentron.com
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. Adding PBPro code to an ASM file - how to?
    By wjsmarine in forum mel PIC BASIC Pro
    Last Post: - 9th January 2010, 19:49
  3. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  4. Loop with two motor and 2 sensors
  5. Making Program Code Space your playground...
