Help please.
The PIC is an 18F8772 on a Futulec board (so hopefully the wiring is correct).
I'm trying to use assembler to make the MCU produce two pulse streams for a set number of pulses:
1. I use TIMER0 and TIMER1 for the inter-pulse delays.
2. A simple 'count down' for the pulse duration.
3. A counter that holds the numer of pulses to be generated, this is decremented - and when the counter hits zero - the routine should end.
The code works OK - BUT! keeps 're-running.' i.e it puts out the required number of pulses, pauses for a bit and then does it all over again.
Debugging with an ICD2 shows all the SFRs changing properly and the code ending after the requisite number of pulses - but when running normally it just keeps looping.
The last few lines of ASM code is
I've not posted all the code because I don't think anyone would trawl through it.Code:Main_loop: ; Check if X_steps_lb is zero tstfsz X_steps_lb ; Test, skip next if equal goto Main_loop ; More steps to do, so loop bcf INTCON,7 ; Disable all high priority interrupts bcf INTCON,6 ; Disable all low priority interrupts bcf T0CON,7 ; Timer0 off bcf T1CON,0 ; Timer1 off end
The CONFIG settings are:
The re-set on MLCR is OK. The IDE is MPLAB. Anyone got any ideas?Code:; Configuration bits CONFIG OSC = HSPLL ; Run at 4X speed CONFIG CP0=OFF ; Disable code protect CONFIG PWRT = OFF ; Powerup off so DEBUG works CONFIG WDT=OFF ; WDT off CONFIG LVP = OFF ; LVP off CONFIG WAIT = OFF ; External bus data wait disabled
Regards Bill Legge
