How to set external clock source in PBP
Results 1 to 29 of 29
Threaded View
  1. #22
    DEFINE ADC_CLOCK 4 ' i know 3 means internal RC, but i want to use the external resonator, is that 4?
    you can't use directly the full speed of external clock. in fact you'll have the external clock divided by n. Refer to section 10 of your datasheet in the ADCON0 table.
    DEFINE OSC 20 ' i know 20 means 20mhz, but does that also work for resonators as well as oscillators?
    20 is the speed of the external oscillator, can be crystal, ceramic resonator, pins on a motor....
    DEFINE SAMPLEUS 50 'i eventually want to sample in the megahertz range if possible,
    I'm also going to eventually put in a trigger to start the A/D process and end it after a certain number of samples. Well, off I go into the pic basic manual. Thanks again for the help.
    The fastest way is to don't use this ADCIN statement and do your sample with FOSC/2 and read/write the internal registers yourself.
    Download and look this code
    with some few modification you'll do it as fast as the PIC can do for you
  1. HW PWM not working
    By comwarrior in forum General
    Last Post: - 31st July 2009, 18:16
  2. Microcode studio - PIC16F877A Interrupts
    By mcbeasleyjr in forum mel PIC BASIC Pro
    Last Post: - 8th January 2009, 07:10
  3. Data Out From External Clock
    By Quin in forum Serial
    Last Post: - 25th October 2008, 10:11
  4. Wierd sleep issue
    By orca in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 23:06
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
