Using parity
Results 1 to 3 of 3
Thread: Using parity
    Nov 2009
    Wagoner, USA
    Default Using parity
    Can the parity be used for error checking? If so how can it be implemented? There is nothing that I can find in the PBP manual.
    You can add a ParityLabel that it will jump to if an incoming byte has a parity error.
    It's in the manual under both HSERIN and SERIN2.
    <br>
    Nov 2009
    Wagoner, USA
    <br>
    Perfect. I'm already using Serin2 with inverted serial out. Looks to be just a simple modification.
    Thanks.
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. Even Parity
    By Andre_Pretorius in forum Serial
    Last Post: - 17th July 2007, 16:48
  3. SEROUT or HSEROUT "ODD" parity
    By RFsolution in forum Serial
    Last Post: - 9th December 2006, 11:34
  4. Parity Modes
    By Sphere in forum Serial
    Last Post: - 29th April 2006, 11:12
  5. Debug with parity?
    By cmolson in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2005, 01:23
