PBP migration from 16F88 to 16F1827
Results 1 to 21 of 21
    Thanks Darrel for the explanation. I guess it's good I cut my teeth on this problem early on. My next (week) project is using an 18F.....good to know what I am in store for.
    Nick
    Hello Darrel,
    I have some more weirdness going on. I got my code to work, but not the way I want it to.
    When I read PortB using LatB, I can't seem to detect a set bit on B1. When I write directly to the
    variable in my case statement I can step through the values and the outputs are correct. I can't
    what is wrong with what I have. Code below.
    __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
    __config _CONFIG2, _PLLEN_OFF & _LVP_OFF & _LVP_OFF & _STVREN_OFF
    DEFINE OSC 8
    ; System hardware configuration
    OSCCON = %01110000 ' 8MHz internal
    ANSELA = %00000000 ' all digital. A/D disabled
    ANSELB = %00000000
    TRISB = %00111111 ' set port directions 0 = output, 1 = input
    TRISA = %00000000
    Servo1 var byte
    Servo2 var byte
    srv2 VAR LATA.1
    srv1 VAR LATA.0
    PrtB VAR LATB
    Program_init:
    PortA = 0
    POrtB = 0
    Main_Loop:
    Servo1 = PrtB and %00000111
    gosub Servo_update1
    Servo2 = PrtB and %00111000
    gosub servo_update2
    pause 10
    goto main_loop
    Servo_update1:
    select case Servo1
    case 0
    srv1 = 1 : pauseus 1000 : srv1 = 0
    CASE 1
    srv1 = 1 : pauseus 1143 : srv1 = 0
    case 2
    srv1 = 1 : pauseus 1286 : srv1 = 0
    case 3
    srv1 = 1 : pauseus 1429 : srv1 = 0
    CASE 4
    srv1 = 1 : pauseus 1572 : srv1 = 0
    case 5
    srv1 = 1 : pauseus 1715 : srv1 = 0
    Case 6
    srv1 = 1 : pauseus 1858 : srv1 = 0
    Case 7
    srv1 = 1 : pauseus 2000 : srv1 = 0
    END SELECT
    Servo_update2:
    select case Servo2
    case 0
    srv2 = 1 : pauseus 1000 : srv2 = 0
    CASE 8
    srv2 = 1 : pauseus 1143 : srv2 = 0
    case 16
    srv2 = 1 : pauseus 1286 : srv2 = 0
    case 24
    srv2 = 1 : pauseus 1429 : srv2 = 0
    CASE 32
    srv2 = 1 : pauseus 1572 : srv2 = 0
    case 40
    srv2 = 1 : pauseus 1715 : srv2 = 0
    Case 48
    srv2 = 1 : pauseus 1858 : srv2 = 0
    Case 56
    srv2 = 1 : pauseus 2000 : srv2 = 0
    END SELECT
    Quote Originally Posted by Macgman2000 View Post
    The LATx registers only control the Output state of the pins.
    When you Read LATx, you are reading the requested Output state.
    If the pin is in Input mode, you need to read PORTx to see the state of the PIN.
    When I switch to portB instead of LATB to read, I get nothing from my code.
    BTW I have 20K pull downs and dip switches tied to +vcc to switch in the bit pattern. There should
    be NO case when the output is nothing....even if pullups or pulldowns are messed up.
    Nick
    Try it with a bitwise & instead of a logical AND.
    You are absolutely correct !!! Thanks for the fresh pair of eyes
    Nick
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
  2. PBP, 16F1827, FSR, and Error 113
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 13th January 2014, 09:04
  3. Can PBP & 16f88 really do 9600,8,E,1
    Last Post: - 7th November 2010, 12:12
  4. Compiler differences between PBP 2.33 & 2.46
  5. Newby- PBP wont compile for 18F (MPLAB)
