Thanks Dave, but I can't use FAT32. The SD card lives inside another device that doesn't play FAT32.
Still researching my options....
steve
steve
The origional SDFS is FAT16.
A cool thing about the SDFS32 is if you build your own card reader thingy it will be able to read or write to either one. It detects the format for you.
mackrackit,
I have been trying to figure out for a while how to send FAT16 or FAT32 files to a SD memory card like Byte_Butcher is trying to do. But using SDFS seems to do the job. Thank you for your help. I also didn't have any idea what SDFS is for.
The file SDReadme.txt shows a serial connection between the MCU and the PC computer. Now my question for you, can this serial connection be replaced by a USB connection by using for example a PIC18F4550? Have anybody achieved this SDFS with a USB connection? Thank you all for your help.
All the serial connection is for is dubugging/monitor want is going on. Once you are happy with the setup all of those lines can be deleted.
USB... I have not played with USB but I do not see why you could not use it for debugging if the PC has a terminal that will work with it.
Thank you mackrackit for your response.
Yes, I guess USB can be used for dubugging and monitor what is going on with the MCU. But, what I really had in mind was to be able to see the information in the SD card through a USB connection as a thumbdrive. This might be a challenging project for me, but like everybody else in this forum I am up to the challenge!
Yep. For $10 you get a 2GB SD card, 2 "othersize adapters", and a USB adapter for the card. (and a little plastic carrying case, not shown)
No hair pulling at all. Just stick the card in the adapter, shove it in yer USB slot and copy files to and from...
steve
