How to find the address of stored data on a SD memory card?
Results 1 to 13 of 13
    California, USA
    If you are using SDFS from MeLabs here is a snippet that might help.
    Errr... welll... no... I'm not using SDFS. In fact I had to do a search just now to find out what the heck you're talking about.
    But I've downloaded the files and have the SDReadme.txt open in front of me now and it looks like this is going to be very helpful for me.
    It looks like I've got some reading to do... will be back later with more questions I'm sure.
    Thanks Dave!!
    steve
    If you want to get into FAT32???
    http://www.picbasic.co.uk/forum/showthread.php?t=11700
    The new link to the file is near the end of the thread..
    California, USA
    Thanks Dave, but I can't use FAT32. The SD card lives inside another device that doesn't play FAT32.
    Still researching my options....
    steve
    The origional SDFS is FAT16.
    A cool thing about the SDFS32 is if you build your own card reader thingy it will be able to read or write to either one. It detects the format for you.
    Miami, Florida USA
    mackrackit,
    I have been trying to figure out for a while how to send FAT16 or FAT32 files to a SD memory card like Byte_Butcher is trying to do. But using SDFS seems to do the job. Thank you for your help. I also didn't have any idea what SDFS is for.
    The file SDReadme.txt shows a serial connection between the MCU and the PC computer. Now my question for you, can this serial connection be replaced by a USB connection by using for example a PIC18F4550? Have anybody achieved this SDFS with a USB connection? Thank you all for your help.
    All the serial connection is for is dubugging/monitor want is going on. Once you are happy with the setup all of those lines can be deleted.
    USB... I have not played with USB but I do not see why you could not use it for debugging if the PC has a terminal that will work with it.
    Miami, Florida USA
    Thank you mackrackit for your response.
    Yes, I guess USB can be used for dubugging and monitor what is going on with the MCU. But, what I really had in mind was to be able to see the information in the SD card through a USB connection as a thumbdrive. This might be a challenging project for me, but like everybody else in this forum I am up to the challenge!
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 00:22
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
