Windows 7 64 bit problem..can anyone help???
Results 1 to 17 of 17
    SWITZERLAND (french speaking)
    Unhappy Re: Windows 7 64 bit problem..can anyone help???
    Thanks Darrel.
    Shall I change all my codes or simply go back to a 32 bits system?
    Just demotivating...
    Roger
    Default Re: Windows 7 64 bit problem..can anyone help???
    Well then...
    I tried following code that still generates errors:
    @ __config  _FCMEN_OFF & _IESO_OFF & _BOD_OFF & _CPD_OFF &  _PROTECT_OFF & _MCLR_OFF & _PWRT_OFF & _WDT_OFF &  _XT_OSC
    And here's the error list:
    Any ideas what I'm doing wrong or missing?
    Roger
    Actually, I noticed the syntax change in my PIC's INC file so I corrected as follow:
    @ __config _FCMEN_OFF & _IESO_OFF & _BOR_OFF & _CPD_OFF & _CP_OFF & _MCLRE_OFF & _PWRTE_OFF & _WDT_OFF & _XT_OSC
    Nevertheless, I still get an error message:
    Roger
    You need to comment the default __CONFIG in the 16F690.inc in your PBP folder.
    Use a semicolon.
    Thanks Darrel,
    It works fine now ;-)
    Roger
    Last Post: - 14th June 2016, 08:55
  2. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 11:38
  3. Microcontroller with 2 way paging application problem
  4. Replies: 0
    Last Post: - 8th February 2006, 14:52
  5. 7 segment digit problem (using Mister E's code)
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th September 2005, 21:25
