Windows 7 64 bit problem..can anyone help???
Results 1 to 17 of 17
    Feb 2010
    Unhappy Windows 7 64 bit problem..can anyone help???
    im trying to run MCSP 3.0.0.5 and PBP 2.47 on windows 7. I've managed to fix other problems with the compiler and the version of MCSP using these links
    http://www.picbasic.co.uk/forum/show...ight=windows+7
    http://www.mecanique.co.uk/code-stud...de_notice.html
    now when i compile i get "c:\pbp\PM.EXE cannot start or run due to incompatibility with 64-bit version of Windows"
    i tried changing the compatibility mode for PM.EXE and tried using as administrator with my regular log in and logged in as administrator but i still get the same error.
    anyone have any ideas????? I've searched but cannot find any....
    thanks
    You can not use PM as the assembler when using 64bit version of Windows, you must use MPASM.
    Feb 2010
    Talking
    thank you!!!!!!!!!!!!!!!!!!!!!!!!
    finally everything is right and now i can use my new laptop
    Aug 2005
    Ontario, Canada
    Smile Windows 7 Virtual XP
    For anyone having problems with X64 programs/drivers etc.
    I have a programmer that would not run on Vista x64. Xeltek 3000U
    Xeltek does not support new operating systems for this.
    I installed Windows 7, downloaded and installed Windows Virtual XP (it's free)
    Everything runs great.
    Apr 2009
    really
    is there compability with vista 64 bit computer?
    Help?
    Oct 2003
    holland
    I have a 64 bit Windows 7 computer.
    I run PBP 2.60 as the compiler.
    I use MPASM as the asembler.
    I use PICKIT2 as the programmer.
    And I use (please don't laugh) CDlite as the editor (I' am an oldfashion guy ).
    I do make several different programms a month.
    And I dont have any problems at all.
    So Windows 7 64bit is a great operating system.
    Apr 2009
    I have a vista 64 bit windows computer.
    I use MCS plus 3.0.0.5
    I use PBP 2.50 and PBP 2.60
    But I have a problem
    This is problem.
    Oct 2003
    holland
    Als already said in this topic:
    USE MPASM instead of PM.
    Then the problem is gone.
    Last Post: - 14th June 2016, 07:55
  2. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 10:38
  3. Microcontroller with 2 way paging application problem
  4. Replies: 0
    Last Post: - 8th February 2006, 13:52
  5. 7 segment digit problem (using Mister E's code)
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th September 2005, 20:25
