Hserin
Results 1 to 12 of 12
Thread: Hserin
    Jan 2010
    When I use single letters or numbers it works like a charm but I would like to use longer strings such as "A23". Anything longer then one character and I get errors. Is this a limitation of picbasic?
    Wink
    I think the answer simply is in your Manual ... HSerin Modifiers section.
    Sep 2005
    Campbell, CA
    The following is a technique that I got from Darrel Taylor. It will input a string, and search it for any number of strings.
    Note that the "timeout" in the ArrayRead command is the number of characters in the string you are looking for during that pass.
    HSERIN2 300,InputTimeout,[Str CharArray\12\10] ; Take in max 12 chars optionally terminated by LF.
    ARRAYREAD CharArray,19,FailedFirst,[WAIT ("FirstStringToLookFor")]
    Goto FoundFirstItem
    FailedFirst:
    ARRAYREAD CharArray,21,FailedSecond,[WAIT (SecondStringToLookFor")]
    Goto FoundSecondItem
    FailedSecond:
    Charles Linquist
    Sep 2005
    Campbell, CA
    I should always learn to read my text before hitting SUBMIT. In the example, I have it inputting only 12 chars, while it is testing for a substring of 19 or 21 chars - but you get the idea.
    Charles Linquist
    Jan 2010
    Thank you! I will give this a try.
    Hi, Gator
    Did your pic decided to start ???
    http://www.electro-tech-online.com/m...-anything.html
    BTW, here is the best place to ask about PBP programs ...
    Jan 2010
    Not yet, it turned out to be a programmer error that I wasn't catching. At first it was giving a valid program response then I noticed that it still had an old program on the pic I was using. Building a new programmer today. Its ready to etch now, just waiting 'til morning to finish it.
    And yes, picbasic has been the greatest thing since the pic came out! I can't stand programming with asm.
  1. HSERIN and XOUT command
    By aratti in forum General
    Last Post: - 12th May 2009, 12:58
  2. Instant Interrupts and HSERIN
    By Rob in forum mel PIC BASIC Pro
    Last Post: - 31st January 2009, 06:13
  3. TMR0 interrupt and HSERIN
    By boban in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 12:48
  4. 16F877a Interupt driven Hserin
    Last Post: - 3rd November 2006, 01:38
  5. Hserin
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 27th November 2004, 16:42
