Serin EEPROM Programmer
Results 1 to 12 of 12
    Feb 2010
    Albuquerque
    Default Serin EEPROM Programmer
    I have spent two days trying to figure this out. I have a feeling it has to do with the SERIN command. Please help.
    define OSC 4
    Define CHAR_PACING 500
    CMCON0 = 7
    ANSEL = %00000000
    cont con %10100000
    scl var GPIO.5
    sda var GPIO.4
    sout var GPIO.2
    sein var GPIO.1
    addr var byte
    wr var byte
    val var byte
    serout sout, 6, ["To write to EEPROM press w", 13, "To read EEPROM press r", 13]
    serin sein, 6, wr
    if (wr = "w") then goto ewrite
    if (wr = "r") then goto eread
    ewrite:
    serout sout, 6, ["Write", 13]
    serout sout, 6, ["Enter address 0 - 15", 13]
    serin sein, 6, addr
    serout sout, 6, ["Enter value 0 - 255", 13]
    serin sein, 6, val
    i2cwrite sda, scl, cont, addr, [val]
    pause 10
    serout sout, 6, ["Write complete", 13]
    eread:
    serout sout, 6, ["Read", 13]
    serin sein, 6, addr
    i2cread sda, scl, cont, addr, val
    pause 10
    serout sout, 6, [#val, 13]
    serout sout, 6, ["Read complete", 13]
    Hello dirtbiker. . .
    Welcome to the forum.
    Please Give us a hint, which PIC are you using?
    Just right off the top of my bald head . . .
    TRISIO=%00000010
    Feb 2010
    Albuquerque
    Default pic12f683
    I am using the pic12f683
    May 2008
    Italy
    i2cread sda, scl, cont, addr,[val]
    Additionally variable addr must be a word not a byte!
    Al.
    Feb 2010
    Albuquerque
    Default Reply
    I changed TRISIO, put brackets around the [val] variable and changed addr to a word sized variable .When I start up the microcontroller it sends the first serial out command to the computer but when I send a serial command to the microcontroller from the pc the microcontroller goes into a loop and repeats the first serial command non stop until I disconnect the power.
    define OSC 4
    Define CHAR_PACING 1000
    CMCON0 = 7
    ANSEL  = %00000000
    TRISIO = %00000010
    cont  con %10100000
    scl   var GPIO.5
    sda   var GPIO.4
    sout  var GPIO.2
    sein  var GPIO.1
    addr  var word
    wr    var byte
    val   var byte
        serin sein, 6, wr
    ewrite:
    serin sein, 6, addr
    serin sein, 6, val
    pause 10
    eread:
    serin sein, 6, addr
    i2cread sda, scl, cont, addr, [val]
    pause 10
    Quote Originally Posted by dirtbiker5627 View Post
    define OSC 4
    CMCON0 = 7
    ANSEL  = %00000000
    TRISIO = %00000010
    cont  con %10100000
    scl   var GPIO.5
    sda   var GPIO.4
    sout  var GPIO.2
    sein  var GPIO.1
    addr  var word
    wr    var byte
    val   var byte
        serin sein, 6, wr
    ewrite:
    serin sein, 6, addr
    serin sein, 6, val
    pause 10
    eread:
    serin sein, 6, addr
    pause 10
    Where does it go if wr<>r and <> w?
    Main
    Give yourself a third option to gather serial data, if wr has z in it and never receives the r or w or receives R or W
    it will loop in main forever. You could serout sout,6,[" I received ",#wr] so you know what it got . . .
    May 2008
    Italy
    Since you made variable addr a word then you have to change your serin command to receive two bytes to be combined into one word. This means you have to Tx two bytes (SERIN is unable to receive word)
    serin sein, 6, addr
    serin sein, 6, addr.byte0,addr.byte1
    Al.
    Feb 2010
    Albuquerque
    Default Reply
    I have decided to narrow it down just to the SERIN command. I made a program to read the serial command from the pc and then transmit it back to the pc. When I send the serial data to the pic the transmit light flashes so I know the pc is sending the serial data but the pic is not retransmitting it back to the pc. I am using the debug terminal from the basic stamp program and Parallax USB2SER Development Tool.
    val var byte
    TRISIO = %00000010
        serin GPIO.1, 6, [val]
        pause 10
        serout GPIO.2, 6, [val]
        pause 10
    May 2008
    Italy
    SERIN doesn't need square bracket. Within bracket you will place the qualifier, not the variable.
     serin GPIO.1, 6, val
    Al.
    Feb 2010
    Albuquerque
    Default Reply
    I took the Brackets off the SERIN command and it still does not work.
    May 2008
    Italy
    The USB2SER is not able to program BASIC Stamp® microcontroller modules. BASIC Stamp modules
    require an inverted signal. If you need to program a BASIC Stamp use the FTDI USB to Serial Adapter
    The above is from USB2SER data sheet, and it seems you should use TRUE STATE. Tray to change to:
    serin GPIO.1, 2, val
    and
    serout GPIO.2, 2, [val]
    (see PBP manual pag 130)
    Al.
    Feb 2010
    Albuquerque
    Default Figured it out
    I hooked up the serial input from my pc and tested it on my oscilloscope. What I got was not a serial data string but something similar to a triangular waveform. I looked up the datasheet for the ftdi chip. I fixed it by adding a pulldown resistor to the output of the ftdi chip. Thanks for everybodys help.
    val var byte
    TRISIO = %00000010
    CMCON0 = 7
    ANSEL  = %00000000
        if (val = "a") then ser
    ser:
    Serout GPIO.2, 6, ["Got a"]
    pause 10
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 04:17
  3. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 03:46
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 07:26
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
