did we mention FP Math?
Results 1 to 10 of 10
    Jul 2005
    Smile
    Hello
    I agree with all you guys
    Its the matter of, Do I really need floating point.
    I have written a code to control PGA2311 and view the volume reading on LCD. At first place I was very sad, when I looked to the datasheets, the formula to calculate the decible value was a hell:
    dB = 31.5 - ( 0.5 * ( 255- vol ) )
    I thought the only solution was the floating point, any way, thanks to a friend who told me to use * 10 and * 100 approach :
    dB_VALUE : ' Calculations for decible equivalent values
    IF ( VOL_L >= 192 ) Then
    DB_SIGN = 1
    DB = 3150 - ( 5 * ( 2550 - ( vol_l * 10 ) ) )
    DB10 = DB / 100
    dB1 = DB // 100
    DB1 = DB1 / 10
    Else
    DB_SIGN = 0
    dB = ( 5 * ( 2550 - ( vol_l * 10 ) ) ) - 3150
    DB10 = DB / 100
    dB1 = DB // 100
    DB1 = DB1 / 10
    EndIF
    dB_LCD : ' Show volume on the LCD
    FLAG = 1
    if ( db10 == 0 ) AND ( DB1 == 0 ) THEN
    LCDOut I, clr, " Volume ", DEC DB10, " dB"', DEC VOL_L
    FLAG = 0
    IF ( flag == 1 ) and ( DB_SIGN == 1 ) Then
    LCDOut I, clr, " Volume ", DEC DB10, ".", DEC DB1, " dB"', DEC VOL_L
    IF ( flag == 1 ) and ( DB_SIGN == 0 ) Then
    LCDOut I, clr, " Volume -", DEC DB10, ".", DEC DB1, " dB"', DEC VOL_L
    The compiled code was 970.
    When I used PICBasic Plus, and used floating pint stuff, the code was 1680 words. I now really know the Pros and Cons of floating point stuff, so, as an advice, don't ever use it, unless you badly need it
    See ya
    Default Need code example for PGA2311
    Hi:Would you have some code to share regarding the PGA2311 chip,I would like to try to experiment with this device.I just purchased picBasic pro.
    Thanks Bob C.
    BertMan's Avatar
    BertMan Guest
    Quote Originally Posted by rcbandwidth
    Thanks Bob C.
    Great first post location choice there Bob. Back to the subject....You also have to keep in mind that some devices are preinterfaced with float32 out, which means you have to come up with some kind of solution if you want to use a pic.
  1. Line Graph, math problem...
    By TerdRatchett in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 05:20
  2. PBPL Math...new math takes more cycles...Always?
    Last Post: - 10th February 2008, 11:22
  3. Why can't PIC's support fp math
    By jheissjr in forum mel PIC BASIC Pro
    Last Post: - 3rd August 2006, 09:09
  4. not quite understanding the MATH function
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 17th January 2006, 21:20
  5. Double (or Quad) Precision and FP math
    By NavMicroSystems in forum PBP Wish List
    Last Post: - 24th January 2005, 20:25
