PIC16F688 Disable MCLR?
Results 1 to 3 of 3
    Default PIC16F688 Disable MCLR?
    Could someone please show me how to disable the MCLR on a PIC16F688? I have been searching and trying for hours now and everything I find throws compile errors and I can't seem to make sense out of what the datasheet says.
    Bombay, India
    Default Re: PIC16F688 Disable MCLR?
    You could try adding this line at the top of your code
    @ device INTOSCIO
    This tells the compiler to set the fuse to make MCLR an IO pin and use the internal oscillator. More definitions are in the file M16F688.INC in your INC folder of PBP
    atif12's Avatar
    atif12 Guest
    • This tells the compiler to set the fuse to make MCLR an IO pin and use the internal oscillator. More definitions are in the file M16F688.INC in your INC folder of PBP
  1. PIC16F688 Timer1
    By jmbanales21485 in forum mel PIC BASIC Pro
    Last Post: - 18th July 2007, 01:56
  2. PIC16F688 USART problem
    By Kees Reedijk in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2006, 05:59
  3. LCD(pic16f688)
    By tarr in forum mel PIC BASIC Pro
    Last Post: - 23rd March 2006, 22:16
  4. pic16f688
    Last Post: - 20th March 2006, 17:46
  5. Seeking Help With Programming PIC16F688
    By gzayzay in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 04:32
