8x8 keypad matrix...
Results 1 to 6 of 6
    Oct 2008
    Default 8x8 keypad matrix...
    Hi, I got my 4x4 keypad working using keypad.bas file from Setve. Now I'm trying to modify it to create 8x8 PortB for rows and PortD for Columns. Kindly check my codes and schematic, I use 1k for the resistors.
    TRISB = %00000000
    PortB = 0
    TRISD = %11111111
    PortD = 1
    ADCON1 = 7 		;Make PORTA and PORTE digital
    OPTION_REG.7 = 0
    INCLUDE "KeyPad.bas"
        '    Hardware connection
        DEFINE KEYPAD_ROW        8       ' 8 row
        define KEYPAD_ROW_PORT   PORTB   '   on PORTB
        DEFINE KEYPAD_ROW_BIT    0       '
        DEFINE KEYPAD_COL        8       ' 8 col
        DEFINE KEYPAD_COL_PORT   PORTD   '   on PORTD
        DEFINE KEYPAD_COL_BIT    0       '
        '    Serial Communication definition
        DEFINE HSER_TXSTA 24h            ' enable transmit, BRGH=1
        DEFINE HSER_SPBRG 129            ' 9600 Bauds
        '    Variables definition
        myvar                    var byte
        '    ---------------------------------[Program Start]----------------------------------------------
    start:
        @ READKEYPAD _myvar
        hserout ["Key=",dec myvar,13,10]
        goto start
    thanks in advance,
    mbox
    Hi mbox,
    Please, always, always post the PIC part number as some really are very different. I have gotten to the point of making a comment in all my code with that information.
    Did this work for you with the serial output on the "other" chip you were using?
    What chip "was" that?
    Did you edit keypad.bas to alert it as to the changes? (Best I remember it defines everything on PortB . .) .
    I have had no success porting the program Steve wrote for LLoyd Edwards to use serial LCDs, (did I remember to say thank you LLoyd?), Thank You LLoyd. I will have to revisit it as i probably did something bone headad like try to use Tx pin as output . . .
    Mar 2008
    Gerogetown, Texas
    here is some code I use for a 8X10 switch matrix I think you will get the idea how to modify it for a 8X8 matrix. I do not remember where I got the matrix part of this code so I can not give credit to the author. By the way I do not use any resistors. Works fine for me without.
    DEFINE OSC 48
    ADCON1 = $F       'port A digital
    CMCON = 7         'PortA Digital
    PortE.7 = 1              'set weak pullups port D
    USBBufferSizeMax   con 8  ' maximum buffer size
    USBBufferSizeTX    con 8  ' input
    USBBufferSizeRX    con 8  ' output
    ' the USB buffer...
    USBBuffer        Var Byte[USBBufferSizeMax]
    USBBufferCount   Var Byte
    TrisB = %00000000
    TrisD = %11111111
    TrisE.0 = 1
    TrisE.1 = 1
    shift  var byte
    keyout var byte
    keyold var byte
    K_Flag Var Bit
    Key	   Var Byte
    Debounce 	Var 	Bit 	  	' Flag to indicate a keypress.
    D_Flag 		Var 	Bit 	  	' Debounce flag used by Inkeys.
    keysend var byte
    D_Flag=0
        '   Interrupt definition
            '   USB interrupt used to keep USB connection alive
    INCLUDE "DT_INTS-18.bas"    ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"     ' Include if using PBP interrupts
    INT_LIST  macro    ; IntSource,         Label,  Type, ResetFlag?
            INT_Handler    USB_INT,  _DoUSBService,   ASM,  yes
    usbinit ' initialise USB...
    USBService                                    ' keep connection alive
    UIE = $7F
    UEIE = $9F
    @   INT_ENABLE  USB_INT
    goto ProgramStart
    ' This subroutine Scans the 16 button keypad and returns the key pressed in "KEY"
    ' If no key is pressed the value returned is 128.
    ' It also returns a Bit-Flag called DEBOUNCE which is 1 if a key is still in use
    ' And 0 if not. This acts as a debounce for the Keypad.
    Keyscan:
    	Debounce=1				' Setup the initial value for Debounce
    	Key=0					' Clear the variable KEY, prior to scanning
        Portb=%11111110				' Pull the fourth row line LOW
    	Gosub Scancol				' Scan the columns
    	If K_Flag=1 then goto Map		' If a key is pressed then map it
    	key=10
        Portb=%11111101				' Pull the third row line LOW
    	key=20
        Portb=%11111011				' Pull the second row line LOW
    	key=30
        Portb=%11110111				' Pull the first row line LOW
    	key=40
        Portb=%11101111				' Pull the fourth row line LOW
    	key=50
        Portb=%11011111				' Pull the third row line LOW
    	key=60
        Portb=%10111111				' Pull the second row line LOW
    	key=70
        Portb=%01111111				' Pull the first row line LOW
    	Portb=%11111111
    '    key=80
    '    Porta=%11111011				' Pull the fourth row line LOW
    '	Gosub Scancol				' Scan the columns
    '	If K_Flag=1 then goto Map		' If a key is pressed then map it
    '	key=90
    '    Porta=%11110111				' Pull the third row line LOW
        D_Flag=0				' No key pressed, so Reset debounce flag
    	Debounce=0 			        ' No key pressed, so Reset key Debounce flag
    	Goto Exit				' Exit from the subroutine
    ' Do the following code if a key has been pressed
    Map:	portb.0 = 0
    '        if porta.1 = 0 then
    '            shift = 1
    '            else
    '            shift = 0
    '        endif
            If D_Flag=1 then exit 		' Already responded to this press, so exit
    	  D_Flag=1				' Set Debounce flag
    	  Debounce=0 				' Reset key Debounce flag
                                                             'Key Code
     Exit:	Lookup Key,[81,86,88,47,4,84,83,87,82,85,_    '0-9
                        20,0,21,0,0,0,19,24,17,22,_       '10-19
                        65,72,69,48,3,68,67,71,66,70,_    '20-29
                        28,0,29,0,0,0,27,0,25,30,_        '30-39
                        60,64,61,43,8,0,59,63,36,62,_     '40-49
                        44,40,37,42,7,0,35,39,41,38,_     '50-59
                        49,56,53,46,5,52,51,55,50,54,_    '60-69
                        73,80,77,45,6,76,75,79,74,78,_    '70-79
                        0,0,0,0,0,0,0,0,0,0,_             '80-89
                        0,0,0,0,0,0,0,0,0,0],Keyout       '90-99 Map of the keypad legends
        Return					' Exit from the subroutine
    ' This subroutine scans the columns
    ' The bit, K_Flag returns a 1 if a key is pressed, and 0 if no key pressed
    ' Also, if no key is pressed the variable KEY will return with the value of 16
    Scancol:
    	K_Flag=1				' Set K_Flag initially to 1
    	If Portd.0=0 then S_Exit		' Return if a key on the first column is pressed
    	Key=Key+1				' Else increment KEY, and try another row
    	If Portd.1=0 then S_Exit		' Return if a key on the second column is pressed
    	If Portd.2=0 then S_Exit		' Return if a key on the third column is pressed
    	If Portd.3=0 then S_Exit		' Return if a key on the fourth column is pressed
    	Key=Key+1				' Else increment KEY, KEY now equals 16
    	If Portd.4=0 then S_Exit		' Return if a key on the first column is pressed
    	If Portd.5=0 then S_Exit		' Return if a key on the second column is pressed
    	If Portd.6=0 then S_Exit		' Return if a key on the third column is pressed
    	If Portd.7=0 then S_Exit		' Return if a key on the fourth column is pressed
    	If Porte.0=0 then S_Exit		' Return if a key on the third column is pressed
    	If Porte.1=0 then S_Exit		' Return if a key on the fourth column is pressed
        K_Flag=0				' Set the K_Flag to indicate no key pressed
        'key = 0
    S_Exit:	Return					' And exit the subroutine
    ' * receive data from the USB bus                            *
    DoUSBIn:
       USBBufferCount = USBBufferSizeRX              ' RX buffer size
       USBIn 1, USBBuffer, USBBufferCount, DoUSBIn   ' read data, if available
    ' * wait for USB interface to attach                         *
    DoUSBOut:
       USBBufferCount = USBBufferSizeTX              ' TX buffer size
       USBOut 1, USBBuffer, USBBufferCount, DoUSBOut ' if bus available, transmit data
       DoUSBService:    'Keeps USB alive
        usbservice
    @   INT_RETURN
    ProgramStart:
    Again:	gosub Keyscan			  ' Go and scan the keypad
    	If K_Flag = 0 then	  ' If no key is pressed then do the following: -
    	Goto Again			  ' And look again when woken up.
    	Endif
    	'High Strobe  			  ' Enable the Strobe pin
            Pause 200			  ' Delay for 50ms after strobe pin is set HIGH
            if keyold != key then
            usbbuffer[0] = Keyout	  	  ' Transmit the KEY byte
      	    gosub dousbout
            keyold = keyout
    	Goto again			  ' Do it all again!
    Oct 2008
    Thanks for the quick responce, I'm using pic16f877, the same PIC I use for my 4x4 keypad. If possible I want to make use the keypad.bas include file work for the 8x8. I did not make any changes to the keypad.bas but instead I include this in my code...
    I also want to make clear, is the DEFINE KEYPAD_ROW_BIT and DEFINE KEYPAD_COL_BIT is where you suppose to connect your first row and column?
    regards,
    mbox
    Quote Originally Posted by mbox View Post
    regards,
    mbox
    I see mister_e has commented the DEFINES in keypad.bas you should scroll down and see this in amongst the assembly code:
    <font color=green>
        ;    Default settings
        KB_ROW        = 4                                      ; 4 ROW keypad
        KB_ROW_PORT   = PORTB                                  ; Keypad ROW on PORTB
        KB_ROW_BIT    = 0                                      ; ROW0 = PORTB.0
        KB_COL        = 4                                      ; 4 COL keypad
        KB_COL_PORT   = PORTB                                  ; Keypad Col on PORTB
        KB_COL_BIT    = 4                                      ; COL0 = PORTB.4
        DebounceDelay = d'200'                                 ; debounce delay 200mSec
    </font color>
    I do not know if the defines will override this or not, somehow I doubt it, but it very well may.
    Also here are some threads on this subject:
    http://www.picbasic.co.uk/forum/show...ght=keypad.bas
    http://www.picbasic.co.uk/forum/showthread.php?t=3250
    Oct 2014
    Default Re: 8x8 keypad matrix...
    Hello In your code you have enabled pullups resistor to vcc in portb so please change your ports
    because "Column bits must have Pull-up resistor attach to VCC"
    Ex:
    DEFINE KEYPAD_ROW 6 ' 6 row
    define KEYPAD_ROW_PORT PORTC '
    DEFINE KEYPAD_COL 4 ' 4 col
    DEFINE KEYPAD_COL_PORT PORTB '
  1. Matrix Keypad routine
    By mister_e in forum Code Examples
    Last Post: - 18th September 2022, 21:30
  2. calculator-like code entry with matrix keypad and display
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 16th December 2009, 23:58
  3. Need help in matrix keypad coding
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 14:16
  4. Inconsistent output on a 4x4 matrix keypad
    By markcadcam in forum mel PIC BASIC Pro
    Last Post: - 24th November 2006, 04:54
  5. very basic matrix keypad question
    By kitcat in forum mel PIC BASIC Pro
    Last Post: - 8th July 2006, 22:33
