Detecting a pulse
Results 1 to 18 of 18
    Default OK...
    It seems a sentence was left out of my posting!
    I wish to log the power failure durations, times and dates as well and that's why I would like to use a PIC as well an an RTC.
    The PIC cirucit would either form part of an existing circuit or be battery/solar powered and have little or no draw on my home circuit.
    Kind regards
    Dennis
    Quote Originally Posted by Dennis View Post
    Hi all
    Because of the amount of power failures in our area , I am building a circuit to auto-switch my generator because it's quite a mission getting up at 2am sometimes to go and switch it on when there is a power failure.
    I plan to use an opto-isolator initially to detect the power failure however some form of zero-crossing detection may also be a consideration.
    This of course raises a good few (maybe silly for some) questions:
    1.Which would most accurately detect the pulses ? PULSIN or COUNT? are there other methods?
    2.Using either of these does the incoming pulse have to be a known value or can on just check to see if a pulse (of any/unknown size) exists ?
    3.Have I chosen the correct RTC (DS1302) for the job ?
    I have been searching the forum for the last few days but haven't yet found the right example.
    I really would appreciate some advice or guidance on how to detect the pulse and absence of a pulse just to get me started.
    Kind regards
    Dennis
    California, USA
    Aha!
    I figured there must be more to it than just getting the beastie running at 2AM.
    Data logging is a good use for a PIC.
    Just detecting lack of AC power to start a motor is not.
    steve
  1. Pulse Capture and byte building
    Last Post: - 21st July 2009, 02:59
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  3. How to reverse polarity on output pulse??
    Last Post: - 6th June 2009, 14:25
  4. Replies: 3
    Last Post: - 13th September 2008, 18:40
  5. Pulse Frequency Multiplication
    Last Post: - 21st August 2005, 11:39
