Detecting a pulse
Results 1 to 18 of 18
    Bombay, India
    I humbly beg to differ here. Why do you even need a PIC to do this? A simple mains rectifier output indicates power present. Similarly, when the power fails, the reservoir capacitor will hold the voltage a little while before indicating mains failure(takes care of short power glitches if you get them)
    Sizing this value appropriately can give you some delay before you command the generator to switch on.
    In short, mains adaptor -> transistor inverter -> relay is all that is needed to achieve this.
    Sep 2005
    Campbell, CA
    Or an AC relay plugged into an outlet!
    Charles Linquist
  1. Pulse Capture and byte building
    Last Post: - 21st July 2009, 02:59
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  3. How to reverse polarity on output pulse??
    Last Post: - 6th June 2009, 14:25
  4. Replies: 3
    Last Post: - 13th September 2008, 18:40
  5. Pulse Frequency Multiplication
    Last Post: - 21st August 2005, 11:39
