syntax error
Results 1 to 19 of 19
Thread: syntax error
    Quote Originally Posted by malc-c View Post
    I'm trying to use 4 pots to provide a range of values to set the temperature set point in the code featured http://www.picbasic.co.uk/forum/showthread.php?t=12712
    When I use the following code I get a bad expression syntax error on the SetPoint(ADchan) = POTS(ADchan) line
        FOR ADchan = 0 to 3
            GOSUB GetADC
            POTS(ADchan) = ADvalue
        NEXT ADchan
    My logic seems that it gets the adc value, places that in the POTS(0), POTS(1) etc, and then should give SetPoint(0) the same value as POTS(0)
    All I really need is a range between 100 and 500 for each SetPoint
    Have you tried [square] brackets ?
    Hi Malc,
    Use ...
    Setpoints(ADchan)
    Hi Malc,
    Use ...
    Setpoints(ADchan)
    Hmmm . . . so (ADchan) is a MATH operation ? I thought it was an array, if it is, then (brackets) are OK ?
    malc-c's Avatar
    malc-c Guest
    Hi Malc,
    Use ...
    Setpoints(ADchan)
    How the hell did I miss that !
    Now just got to work out how to get the value with in the range !
    Thanks once again Darrel
    Hi Malc, I would say pretty darn easy, given the size of this program, I just un zipped it, nice work ! To all involved.
    malc-c's Avatar
    malc-c Guest
    Thanks, but really the credit for the coding goes to Darrel.
    I'm still a rookie in PBP, and it's taking me hours to try and work this out and I'm still having trouble getting the value from the pot to change the set temperature
    malc-c's Avatar
    malc-c Guest
    Still need help (Darrel ??)
        FOR ADchan = 0 to 3
            GOSUB GetADC
            pots(ADchan) = ADvalue
            SetPoints(ADchan) = (Advalue / 100)
            if SetPoints(ADchan) <200 then SetPoints(ADchan) = 200
            if SetPoints(ADchan) >500 then SetPoints(ADchan) = 500
        NEXT ADchan
    and
    LCDOUT $FE,$C0, DEC pots(0)>>1,"   "
    Gives a value on the LCD of between 1 and 8184 as the pot is turned from one extreme to the other
    however
    LCDOUT $FE,$C0, DEC SetPoints(0)>>1,"   "
    Gives a static number, of 100 regardless of what position the pot is set to
    I would also like to know what to change to get the PC display to show the value of the setpoints - it still remains the same value (26 degrees) set by EE_setpoint value in the initial stages even though I've changed the setmode to manual
    malc-c's Avatar
    malc-c Guest
    Default sorted !
    Managed to get this part to work.
    FOR ADchan = 0 to 3
            GOSUB GetADC
            pots(ADchan) = ADvalue/10
            SetPoints(ADchan) = pots(ADchan)
            LCDOUT $FE,$C0, dec pots(0)>>1,"   "
    Now get a value between 0 and 818 when the pot is moved
  1. Compile error & syntax error on the word "loop:" as a label?
    Last Post: - 7th March 2010, 05:14
  2. Loop with two motor and 2 sensors
  3. Optimizing DIV
    Last Post: - 22nd September 2008, 05:58
  4. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 01:22
  5. Syntax error PIC16F684
    By milestag in forum mel PIC BASIC Pro
    Last Post: - 21st September 2005, 19:54
