Henrik,
I think we were / are describing the same thing, IE a low frequency PWM signal. In that the frequency of the cycle is approx half a second, with a varying pules width between 100% and 0% depending on the closeness the current temperature is to the set point.
I thought Denis was simply running a loop with a set mark / space ratio for a given cycle period. If I thought wrong then I apologize
