4 Channel Thermostat using PID loops
Results 1 to 37 of 37
    Hi Malcolm,
    I don't think Denis is missing anything. What you are doing is some form of PWM, probably at a reasonably low frequency. 100% means the output is on all the time 0% means it's off all the time. At 50% it's on half of the time and off for the other half.
    The question Denis is asking is how long in terms of milliseconds, seconds, hours or days is one period of this PWM signal.
    On slow responding systems or "loads" like your heater for example one period can be long, like several seconds or even longer while on fast responding systems like regulating the current thru a motor or whatever the period needs to be MUCH shorter.
    A 50% duty cycle or output means the output is on 50% of the time but in the first case, with the heater, it means it's on for 5 seconds and off for 5 seconds while in the later case with the motor it means it's on 5us and off for 5us. Still 50% in both cases but in the first the period is 10 seconds, in the later the period is 10us.
    Really it's all a matter of how much "jitter" you can live with on the resulting response from whatever it is you're driving. There's usually no need to use 20kHz PWM if regulating the temperature in an oven where applying "100% power" for one minute will result in a temperature rise of 0.5° - as an example.
    Sorry for the long winded response.
    malc-c's Avatar
    malc-c Guest
    Henrik,
    I think we were / are describing the same thing, IE a low frequency PWM signal. In that the frequency of the cycle is approx half a second, with a varying pules width between 100% and 0% depending on the closeness the current temperature is to the set point.
    I thought Denis was simply running a loop with a set mark / space ratio for a given cycle period. If I thought wrong then I apologize
    malc-c's Avatar
    malc-c Guest
    Default Prototype
    Well a few months have passed and I'm able to get back to this project.
    I used Eagle to design a PCB, but every time I ran the build it required a double layer PCB and my DIY PCB skills resulted in several coasters ! I've just found one of many stripboard design applications and have come up with the attached. Hopefully it won't need modding too much, and will either update the image when completed and tested, or confirm that I've got it right first time (be a miricle )
    I'll also take some pictures of the unit as it's put together and will add them to this thread as I progress.
    Note that before anyone jumps in and states that I need to break tracks around the relays, due to the lack of being able to design a custom component, I had to compromise, the real relay doesn't have all the pins on the package as shown
    malc-c's Avatar
    malc-c Guest
    Default Prototype takes shape
    Well due to work and other personal commitments I've been too busy to turn the drawing into a practical prototype... until today.
    I called into Maplin and purchased some stripboard and a suitable box this morning and then spent an enjoyable afternoon building the board. I've not fully tested it yet, bit on powering up the EasyPIC board and taking a 5v supply and using a test LED, the pins to the LCD flashed the same way as they did on the development board (and there was no smoke )
    Wife has plans to get me to sort out the garden tomorrow... but hopefully I'll find time to build the PSU board, and LCD and test this further before hooking up the mains to the relays. For convenience I'll probably take the sensors straight in through the back panel rather than rig up some connectors... we'll see.
    It's taken me six months since DT (and Henrik) assisted me with developing the code to get this far. With out their help it would of taken me a lot longer. I'm determined to see this through to the end - I feel I owe it to you guys to prove the project works in the real world
    Aug 2005
    Michigan, USA
    Hi Malcom,
    A truly nice project Sir. May I ask if you've developed menu and display subsystems and would you have display examples you might share? Just curious to see how your user interface works.
    Cheerful regards, Mike
    malc-c's Avatar
    malc-c Guest
    Hi Mike,
    The menu's as they stand are fairly basic. If the option button is pressed the main menu is displayed.
    LCDOUT $FE,2,"Main Menu"
    lcdout $FE, $C0, "Select Option"
    IF Option = 1 THEN lcdout $FE, $D4, "Set Time and Date  "
    if option = 2 then lcdout $FE, $D4, "Set Night Period   "
    if option = 3 then lcdout $FE, $D4, "Set Normal Temps   "
    if option = 4 then lcdout $FE, $D4, "Set Lighting Period"
    if option = 5 then lcdout $FE, $D4, "Run                "
    Depending what state you leave the option button set to the LCD display reads
    Main Menu
    Select Option
    Set Time and Date
    The normal temp sub menu simply displays the A/D from the four pots.
    The sub menu for the lighting period simply shows the time which gets changed by the +/- buttons so you can set the on time and then repeated for the off time (for each viv).
    If I get chance I'll take some photo's of each menu and post them up at a later stage.
    malc-c's Avatar
    malc-c Guest
    Default Do not use image in post #11
    Guys,
    Normally when strip boarding I build as I build up the board from the schematic as I go along, and often test each section, ie get the LCD working, then the sensors, then the switches, then the RTC etc. However this time I used an application to design the board and having followed it found that the board contains an error somewhere as the LCD doesn't work. I'm no longer able to edit the post to remove the image so..
    DO NOT USE THAT IMAGE
  1. Simple 4 channel DMX controller
    By eggman in forum Code Examples
    Last Post: - 18th July 2012, 01:40
  2. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 07:56
  3. 4 pin 4 x 4 keypad interface using pic basic pro
    By dunlao_john in forum mel PIC BASIC Pro
    Last Post: - 15th January 2009, 05:21
  5. Real Time Clock & Eeprom
    By smart_storm in forum General
    Last Post: - 17th February 2006, 19:03
