unstable ADCIN readings when using DT ELAPSED.PBP
Results 1 to 9 of 9
    Hi Darrel,
    my fears came truth. I've inherited the codebase and suspected that those parts need updates as I visited your page and saw that updates were released after 2003 BTW: The ELAPSED-18.bas still list 12/16/2003 as date.
    But I lucked out as your promise from the thread holds true: Your *-18.bas files are drop-in replacements for the old versions. No line modified, just the extension changed to .pbp as .bas is reserved for the Visual Basic code.
    The code is reduced to the clock output shown below, the clock counting is working without errors, but the display has artefacts, as about every 10 seconds the display has wrong information in the places of the clock, never where the separators are appearing.
    I need a hint:
    Do we have to protect instructions like ARRAYWRITE or is it rather the SPI were the interrupts are interfering?
    actually: scratch that, it must be the ARRAYWRITE as else the separators would be influenced too. time to read assembler. Stuff that I avoided since 1990.
    if the PAUSE before the last GOTO is removed, the problem isn't visible bt I think the updates are simply happening more often and the problem is still appearing.
    'Code is licensed as http://creativecommons.org/licenses/by-sa/3.0/de/
    '(c) 2010 Ing Buero A. Czech
    DEFINE DEBUG_MODE 1    'Auf 1 setzen, wenn keine Debuggen notwendig
    DEFINE DEBUGIN_MODE 1
    INCLUDE "BS1DEFS.bas"
    INCLUDE "EBS18F2423.pbp"
    INCLUDE "EBSMasterKonf.pbp"
    INCLUDE "EBSMasterVar.pbp"
    INCLUDE "Elapsed-18.pbp"
    INCLUDE "LCDAusgabe.pbp"
    'VP: LCD Initialisierung
    GOSUB EBSLCDINIT
    LCDTextAnz = 16
    GOSUB ResetTime
    GOSUB StartTimer
    ' Hauptprogramm
    HauptSchleife:
        GOSUB EBSLCDZeile1
        ARRAYWRITE LCDText,[DEC2 days, "+", DEC2 Hours, ":", DEC2 Minutes, ":", DEC2 seconds, REP 32\11]
        GOSUB EBSLCDTEXTOUT
        'DEBUG
        PAUSE 500
        GOTO HauptSchleife
    Quote Originally Posted by peter_wiersig View Post
    I chickened out, if I use this construct:
        T1CON.0 = 0                   ; Turn OFF Timer1
        T1CON.0 = 1                   ; Turn OFF Timer1
    the clock is working without problems and the ADC readings are stable. It was the output and not the measurement that had the problem.
    You shouldn't need to turn the timer off. And doing so will affect the accuracy of the Elapsed Timer.
    And the Interrupts won't interfere with the MSSP module.
    I think you just need to wait for the SecondsChanged flag before sending it to the LCD.
    Then it won't be changing the time while you're trying to display it.
    HauptSchleife:
        IF SecondsChanged THEN
            SecondsChanged = 0
            GOSUB EBSLCDZeile1
            GOSUB EBSLCDTEXTOUT
        PAUSE 1
    GOTO HauptSchleife
    Yes, expected the inaccuracy. As our process is finished in ~10 hours this inaccuracy is no issue.
    We are seeing with this code irregular values in the first line and no issues in the second line. The interrupts are interfering with the arraywrite instruction.
    It's never that anything is printed beyond the 10th char but that random characters are printed anywhere in the digits, all zeroes and non-numbers are also seen.
    GOSUB EBSLCDINIT
    LCDTextAnz = 16
    GOSUB ResetTime
    GOSUB StartTimer
    DebugLoop:
    GOSUB EBSLCDZeile1
    ARRAYWRITE LCDText, [DEC10 LCDTextAnz, REP 32\11]
    GOSUB EBSLCDTEXTOUT
    GOSUB EBSLCDZeile2
    GOSUB EBSLCDTEXTOUT
    PAUSE 200
    It appears that you are using PBPL now.
    There was no such thing as PBPL when I wrote the elapsed timer in 2003.
    And that version does not save system vars properly for PBPL.
    I believe you can change the save variables to LONG's and get better results...
    R0save   var LONG
    R1save   var LONG
    R4save   var LONG
    Or, unless there is some reason you really need to use PBPL ...
    Switch back to PBPW.
    You could also use this version of the Elapsed Timer, which is known to be compatible with PBPL.
    http://darreltaylor.com/DT_INTS-18/elapsed.html
  1. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
