Serial Communication
Results 1 to 27 of 27
    micah4242's Avatar
    micah4242 Guest
    Default Solution Found
    After all these years I have finally found what is wrong. In order to send serial the onboard crystal must be at 4mhz or higher. If it is higher it must be setup such as "Define 20". To indicate at twenty. In this post I was sending from a basic stamp which is actually a pic to a pic. My problem was that the pic was not running on a 4mhz clock. Once the clock is updated then the serial comes in just fine
    Mar 2005
    Iowa, USA
    You could have saved yourself 3 years of work by searching through these forums. I can't count how many times it has been mentioned that you should atleast use a 4Mhz crystal for serial communications. I'm sure you would have run into the Define command for clock speed as well. Wow.... 3 years.... really?
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
  1. Wireless serial communication question
    By Ahmadabuomar in forum Serial
    Last Post: - 21st December 2009, 04:49
  2. PIC to PIC "wired" serial one-way communication - SERIN2/SEROUT2
    Last Post: - 14th April 2008, 21:02
  3. Bootloader,MCSP and Serial communication
    By surfer0815 in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2006, 11:52
  4. Serial Communication using 12F629
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 14th March 2005, 05:24
  5. Replies: 8
    Last Post: - 11th November 2004, 21:08
