RS232 to ethernet device
Results 1 to 15 of 15
    There are some settings need to be done in prior. Like the IP address, subnet mask etc to match the local network. It is close to plug and play but not exactly.
    Also if there is an internet connection maybe you can open a port on the modem and you can connect to the device from your PC and make any changes.
    Sep 2005
    Campbell, CA
    All of them (at least the 3 or 4 that I have played with) let you set the configuration over the network OR the serial port.
    The part that you have to consider is whether or not your PIC will control such things as ip address, subnet mask, gateway, protocols, etc.
    If the PIC does not have to control these things, then most any one of them will work. If the PIC DOES have to control these items, then you should pick your device carefully. Some are much easier to configure over serial than others.
    Charles Linquist
    my send rs232 is a pic that will be sending 6 bytes of data (non encoded raw binary) over and over again, that's it.
    my windows software on the receive end deciphers it -- sort of a burglar alarm arrangement.
    I'm still studying these -- looks like the ezweblynx, lantronix xport and ewiznet are all the best choices.
    I'm trying to figure out though, do you need a development board to setup and program these?
    Or can you do it with just a PC and the module?
    Charles, you made it sound like a development board isn't needed -- like I say, I've never even touched one so I like to be extra sure with my (redundant) questions.
    lol.
    Sep 2005
    Campbell, CA
    I use a lot of Lantronix Xports and Lantronix MatchPortAR's. They are single parts that do not have a DB-9 connector. If you install them on your board, then you have two options to configure them. I say "configure" becuase there is no real "programming" needed - the program is already inside and you just set up the parameters you need with a menu.
    From the NETWORK SIDE:
    Lantronix has a program called DEVICE INSTALLER that you run in a PC that is connected to the Ethernet port of the device. You can set up all the parameters: ip, subnet mask, gateway, and a bunch of others. The interface is either a command line or GUI (you choose). This configuration can be done at any time - even in the field if the user has the PORT INSALLER program.
    The ability to use this GUI can be shut off, however. My military customers (virtually ALL my customers are military) demand that it not be possible to re-configure the device from the "network side". Once this GUI is shut off, the device must be configured from the "serial side".
    From the SERIAL SIDE:
    on the XPORT -
    You use your PIC to hold the RESET line, and then release it. You start sending a series of "z". After a few seconds, it will respond with an "*". You then send "S0" followed by a series of INTEL Hex records with a checksum at the end of each. When you are done, you issue a RESET again.
    on the MATCHPORT AR-
    You use your PIC to hold the RESET line, and then release it. You start sending a series of "!". After a few seconds, it will respond with a ">". You then send a sequence of XML records.
    All this is OF COURSE explained in the respective manuals.
    Charles Linquist
    Thanks Charles.
  1. Watchdog Timers
    Last Post: - 27th August 2014, 18:03
  2. RF Modules
    By tonyfelloni in forum mel PIC BASIC Pro
    Last Post: - 26th June 2010, 17:42
  3. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 20:39
  4. Target device <> Selected Device????
    By deepgfishing in forum mel PIC BASIC Pro
    Last Post: - 20th June 2007, 21:18
  5. @ Device Parameters
    By Randy_Suwanee in forum General
    Last Post: - 11th August 2004, 14:40
