Lost Communications?
Results 1 to 7 of 7
    Default Lost Communications?
    Everytime I call for a compile and program the programmer comes on (programming window) and when the program icon is clicked a lost communications screen comes up. I click program again and everything works OK? Anyone else running into this?. Using PBP 2.6 and programming SW.Vr.4.31 (USB programmer). Again this only happens on the first call for programming. Thanks, RC
    Quote Originally Posted by fowardbias View Post
    Hello Forwardbias,
    Not familiar with your programmer BUT the PICKit2 is a USB programmer, and you do not use compile and program, only the compile button and it automatically reloads the hex and programs. BTW it also loses communication if an anomaly (short) occurs on it's load side.
    Default could it be ....?
    Hi Forwardbias
    I initially had some weird issues when programming .. can't remember exactly what they were, but the problem was because I had made a long cable to connect the PIC programming pins to a pin header to the PICKIT2. As it turns out the cable was too long and was causing some really weird issues. The solution was to to make the connections(cable) from the pin header to the PICKIT2 as short as possible, I ended up connecting the PICKIT2 directly to the pin header on the breadboard.
    Something like this:
    Original
    PIC-----------Pin Header<--------------------cable------------->PICKIT2
    Solution
    PIC -----------Pin Header<PICKIT2
    Hope that helps
    Dennis
    Default re:on the lost comm.
    I am using the MeLabs USB programmer for this instance. I have used a home made interface cable (probably a bit long and unshielded) with the PK2 using ICSP with the 16F628A and 877A, no problems.
    Not all programmers have the same driver capabilities. A really quick way to sort that out as
    the problem would be to make a shorter cable. If the problem goes away, you'll know it
    was due to the longer length ICSP cable.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Default re.lost comm.
    The USB programmer is being used with the 40 pin adapter (ZIF thru the 10 pin header, all factory Melabs hardware) directly to the 877A. Not using ICSP here. After programming the chip is moved to the test circuit. I am using the PK2 using ICSP thru MPLAB only. I use the MCS for the melabs projects. Still doubling clicking here? no big deal. RC
  1. Hserin, 1st character always lost!
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 5th June 2007, 13:49
  2. Communications headset tester
    By skimask in forum Off Topic
    Last Post: - 13th December 2006, 15:40
  3. Under communications, an I2C section.
    By blainecf in forum Forum Requests
    Last Post: - 26th July 2006, 20:59
  4. PIC Basic Pro <-> HP-IL communications
    By swr999 in forum Serial
    Last Post: - 6th March 2006, 19:30
  5. PIC Basic Pro <-> HP-IL communications
    By swr999 in forum mel PIC BASIC Pro
    Last Post: - 6th March 2006, 19:22
