I'm using a 16f877a on a Lab X-2 board, at 20mhz. I'm using microcode studio plus w/PBP and MicroCode Loader bootloader.
My program has an assembly interrupt routine, which to my knowledge is correct. I have a simple:
LED = 1
pause 50
LED = 0
goto Main
Other_Routines:
Although right now my program DOES NOT use "Other Routines"... they somehow affect my program. If I move my encoder, which triggers the assembly interrupt, and I have not commented out "Other Routines", there is considerable lag in the time the LED blinks on off. If I delete a large portion of my unused routine (other routine) then the LED blinks on/off normally dispite the huge number of interrupts, which don't take a long time to process.
I am totally lost. Without the "other routines" my code only takes ~800 words. With it, it's over 1100. I'm wondering if I'm going into a different page, but then I"m not sure because my code is still less than 2k words... if I did go into a new page... what are the consequences of that?
Matt
