3 Phase Angle Control
Results 1 to 12 of 12
    May 2010
    Thanks for yours answers..but I am confused anyway..
    @sougata: do u think that use 2 scr and not 1 triac for any phase improve the load controller? why? In that way I need 6 pwm output (instead of only 3).
    @mark_s: I'm reading "motion feedback module" section and it's really interesting. The problem is that my pic input are three zero crossing phase and I would like control inductive load (like motors) with different phase displacement.
    Feb 2005
    Kolkata-India
    Default Only 3 needed
    Triacs commute at the zero cross. However due to current lag the voltage zero cross and the current zero cross do not coincide. So the other half part of the triac can come into conduction thus phase angle control is not achieved. If you use a 1:1:1 pulse transformer then the firing signal is fed to the pulse transformer. You can AND a logic drive with a 10 KHz PWM of 10%-25% duty to derive the final driving signal for the PulseTr. The two isolated windings then serve the purpose of firing to Anti-Parallel connected SCRs. So you need 3 drive signals only and not six.
    Sougata
  1. 3 phase supply detector challenge
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 15th May 2009, 08:54
  2. Understanding 3 phase sequencing
    By ardhuru in forum General
    Last Post: - 22nd June 2008, 11:14
  3. 3 phase sequencing
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 26th May 2007, 08:35
  4. Someone help me to simplify this
    By thrix in forum General
    Last Post: - 21st February 2004, 06:01
  5. Help wanted..
    By thrix in forum mel PIC BASIC Pro
    Last Post: - 18th February 2004, 00:44
