3 Phase Angle Control
Results 1 to 12 of 12
    Sep 2005
    delhi
    Question
    Quote Originally Posted by BobEdge
    Hi All,
    Anyone have any experience of using just one pic for 3 phase phase angle firing. I know i need to detect the zero crossing points, sort out what order the phases are in, and then fire the appropriate thyristor (six thyristors in all). I am using 50Hz at the minute but will need it to work on 60Hz too, auto detecting frequency is even better
    It all seems a little daunting at the moment, but i know it can be done.
    Thank you in anticipation
    Kind regards
    Bob
    Dear bob
    i am also trying to do the same thing but unable to do in software.
    If you need any theoritical explanation i can help but trying to do in pbp not succeeded till now
    thanks
    pramod
    niall's Avatar
    niall Guest
    Hi All,
    This wouldn't have anything to do with active regeneration/braking(for DC servo motor drives) - would it? Wrote my electronics degree dissertation on this if I can be of any help. Decided not to use a PIC (but did write some code). A PLL and a CPLD is a much neater and less time consuming solution than a microcontroller, (spent many, many hours of development on this ) but I'll try and dig the code out for you if you would like. let me know what you think, may also be able to provide you with some documentation regarding firing angles etc. and development notes if they help
    Neil
    Hi Neil,
    After you fire one phase, can you not just fire the second and the third after a delay of 3.33 ms and 6.67 ms respectively (for 50 hz)?
    The delays would change proportionately for 60 hz, of course.
    I have not tried this, but in a different context, this is what all X10 transmitters do to ensure that *all* three phases receive a signal during their own zero crossing.
    Anand
    niall's Avatar
    niall Guest
    Hi there,
    Yes you can do that, however if there is any slight phase shift in any of the three phases, the crossover angles (and hence the timing!)will change. This is the biggest problem with using just timing to fire the thyristors in the inverter. The easiest way to ensure that this does not happen is to use a PLL (phased locked loop - a lot easier than you might think!) synchronised with phase AB (ph C can be derived mathematically so don't need to worry about this and we can add some dead-time to allow for any phase shift) thus ensuring any phase shift can be detected.
    The beauty of a PLL is that it does not matter what the input frequency is as all you are doing is detecting the crossover angles and syncing with them (you can use an analogue comparator to do this with about 3/4 discrete components. Use the PIC to count output pulses of the comparator and then fire your thyristors! And hey presto active braking/regen!
    Let me know if this is of any help, if you require more in-depth info just say so and I can provide timing diagrams and I could probably put a simple circuit diagram together, I will however need to know what its application is so that I can implement some extra protection in the way of delays etc. for you.
    There are other simpler PIC only ways of doing it by detecting the frequency of ph AB and just timing it, but these are scary if you are dealing with high-voltages.
    Neil
    Feb 2005
    Kolkata-India
    Default It can be done with a PIC
    By measuring the period between one zero cross to other it is possible to to get the frequency of the input frequency. If you are turning off the TRIACS/SCR while a zero cross occurs then there should be no problem. All you need is a timer locked to the first AC input (R) and have some pseudo timers running in software which gets reset at zero cross signals from the other sources (You need 3 interrupt sources). The only problem is that with a 8 bit timer you get a low resolution. With one 16 bit and 2 virtual 16 bit counters the process is further complicated. I posted a thread (I do not remember now) for dimming various channel with a PIC16F84. It was not tested by me and basically an adaption of my big brother program. It is heavily commented and might help out in your algo design.
    My suggestions are :
    1. Strictly asm interrupts
    2. High Priority 18F interrupt vector
    3. High Oscillator speed (I use x4 PLL @ 10 MHz with 18F452 )
    My design is a commercial one and cannot share the code thus. However always willing to help out (within my scope of little knowledge).
    I have the habbit of looking into the PRO forum only so overlooked this thread.
    BTW Pramod I lost your telephone number. One of my partner is right now in Delhi for some component purchase and needs your assistance. Please drop me a private mail or to my regular email with your Phone No.
    Thanks and Regards
    Sougata
    oldtoddler's Avatar
    oldtoddler Guest
    Thumbs up Firing a thyristor @ xcross...
    Why don't u simply use optoisolator like MOC3063? it's zero crossing triac driver and I have used few thousands of those without any problems... and they cost about 1eur@farnell.. If u are after power adjusting, then thyristors are not a proper componets due RF-noice.. IMHO..
    /MRa
    May 2010
    Default inductive motor..
    Hi! I have a question for the same problem..
    I'm using 3 zero crossing detector with 3 optoisolators..
    The problem is that the load of the motor is an inductive type and the triac stops at the zero current...that is not the zero voltage.
    I think that the solution could be starting the firing angle at the shift current phase..
    Any suggest?
    Thanks.
  1. 3 phase supply detector challenge
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 15th May 2009, 08:54
  2. Understanding 3 phase sequencing
    By ardhuru in forum General
    Last Post: - 22nd June 2008, 11:14
  3. 3 phase sequencing
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 26th May 2007, 08:35
  4. Someone help me to simplify this
    By thrix in forum General
    Last Post: - 21st February 2004, 06:01
  5. Help wanted..
    By thrix in forum mel PIC BASIC Pro
    Last Post: - 18th February 2004, 00:44
