My DT interupt is broken
Results 1 to 5 of 5
    sinoteq's Avatar
    sinoteq Guest
    Default My DT interupt is broken
    Hi all
    I have gotten a new computer and of course the things that used to work does not work anymore. Oh yes, I also have upgraded to PBP2.60 and MPLAB 8.33 and I am compiling for 18F4620 or that is what I try to do
    When I include the brilliant DT files they make the compiler unhappy. Yes the files are in the PBP folder and I get this error code:
    ERROR: Unable to execute mpasmwin.Error[116] C:\PROD\X-10 G4 SPEL\INT GEN 4 VAST.ASM 940 : Address label duplicated or different in second pass (Z00031)
    Error[116] C:\PROD\X-10 G4 SPEL\INT GEN 4 VAST.ASM 1003 : Address label duplicated or different in second pass (Z00032)
    Error[116] C:\PROD\X-10 G4 SPEL\INT GEN 4 VAST.ASM 1056 : Address label duplicated or different in second pass (Z00033)
    Error[116] C:\PROD\X-10 G4 SPEL\INT GEN 4 VAST.ASM 1087 : Address label duplicated or different in second pass (Z00034)
    Halting build on first failure as requested.
    BUILD FAILED: Mon May 10 10:39:18 2010
    If I look in the ASM file for Z00031 I find this:
    ; C:\PBP\DT_INTS-18.BAS 00313 Z00031 asm
    Z00031
    ASM?
    ; -- Added for ver. 3.2 --
    ifdef SPPIF ;----{ Streaming Parallel Port Read/Write }--[PIR1, SPPIF]---
    INT_Source PIR1,SPPIF, PIE1,SPPIE, IPR1,SPPIP
    ifdef BCL1IF ;----{ Bus 1 Collision }--------------------[PIR2, BCL1IF]---
    I bet someone have seen this before or at least can give me a clue where to go hunting or do I need Mr DT to go hunting in the 3.2 version upgrade?
    I need my DT interupts!
    Mike
    Hi, Sinoteq
    You should upgrade MPLAB to 8.50 ...
    friendly advice ...
    I saw this problem a while ago ... I think I have posted in the DT Interrupts section. I sent a Mail to Melabs too ...
    BTW ... I just installed an unused PBP in its default folder ( the "used" PBP program is in the MPLAB folder !!! ) ... and everything went fine.
    Melabs didn't have a word about that ... shhhht, do not repeat it !!!
    sinoteq's Avatar
    sinoteq Guest
    Default No luck
    Thank you for your advice but the problem still exist with MPLAB 8.50 I have erased everything from my program except the Includes for the DT files but it still comes out as error.
    Any other ideas?
    One more question: What is the option -k# in the command line? I can only find -k- and -k+ in the manual
    Do you have the newest version of DT_INTS18 v3.4? You need that for 2.60. It can be found here:
    http://www.picbasic.co.uk/forum/show...2826#post82826
    sinoteq's Avatar
    sinoteq Guest
    Default Yes!
    Thank you very much, I am now the lucky owner of working DT interupts again. Maybe, just maybe mr T should release this on the website so more people can find it.
