I would use an 18F8723 running at 40 to blink a LED!
Those big parts were the reason I had to start modifying the libraries in the first place. I needed to access the upper half of memory using PBP 2.47. By setting TBLPTRU to *my* variable (usually "1") instead of clearing it, WRITECODE, READCODE, ERASECODE became a lot more usable - and no LONGs were needed. Setting it to $30 is fun, too. I clear it when I exit the routine so that I don't make PBP mad.
My latest concoction uses two '8723s strapped together (for more I/O and processing power), with a 12F675 also on the board for good measure.
Intel is up to 4 cores, but I'm catching up!
