EEPROM / interrupts
Results 1 to 9 of 9
    Sep 2005
    Campbell, CA
    Bummer!
    Too bad it doesn't save INTCON, clear it, then restore it after the WRITE.
    I'm turning INTs on and off a lot of places in my program.
    Charles Linquist
    Hey Charles,
    I hear you. But it's really easy to modify your PBP libraries. Just make sure you keep a copy of your library mods, since the next update will overwrite everything you've changed.
    And, if it's a patch, you'll get that dreaded "hey .. no-can-do since you have a modified library..;o)
    Still the best compiler on the planet.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2005
    Campbell, CA
    I didn't want to admit it, but I have already made about a dozen changes to the library.
    I made the change I described about an hour ago. It even works!
    Charles Linquist
    I kind of figured you had, but I didn't want to tip-off the PBP police...;o)
    You still using those HUGE 18F parts for everything?
    -Bruce
    tech at rentron.com
    Sep 2005
    Campbell, CA
    I would use an 18F8723 running at 40 to blink a LED!
    Those big parts were the reason I had to start modifying the libraries in the first place. I needed to access the upper half of memory using PBP 2.47. By setting TBLPTRU to *my* variable (usually "1") instead of clearing it, WRITECODE, READCODE, ERASECODE became a lot more usable - and no LONGs were needed. Setting it to $30 is fun, too. I clear it when I exit the routine so that I don't make PBP mad.
    My latest concoction uses two '8723s strapped together (for more I/O and processing power), with a 12F675 also on the board for good measure.
    Intel is up to 4 cores, but I'm catching up!
    Charles Linquist
    I thought so. You're just like my best friend who drives a ferrari to pick up hamburgers
    for our football game get-togethers.
    He also drives an el-cheapo Ford truck, but only to pick up rocks for his landscaping....;o)
    -Bruce
    tech at rentron.com
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 04:17
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 07:26
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
