Logical vs Bitwise ==
Results 1 to 8 of 8
    Default Logical vs Bitwise ==
    Hello Everyone,
    I understand the difference between & vs &&, and I understand >= , <= , but what is the difference between = , and ==, is this just some "C" sneaking into peoples code or is there an esoteric difference here ? Or did I just miss that page in DAS BOOK ? As a comparison operator is there a difference ?
    Bewildered
    As a comparision operator they both do the same thing.
    As a statement only "=" will work.
    Why the MeLabs folks did it this way is anyones guess.
    Thanks Dave, I pretty much thought so, Never tried using double = as a statement, so that's good to know too.
    Ok I just found this, re: double equal sign in " C "
    From Jan 2010 Circuit Cellar
    author: George Martin
    page 70
    "Consider the statements if (a=b) and if (a==b). Both are
    correct, but they are vastly different operations. The former copies the
    value of variable b into variable a, and then if that value
    is nonzero (TRUE) it executes the next statement. The latter compares
    variable a to variable b . If they are equal, then the next
    statement is executed. It is a common mistake to leave out the double
    equal sign."
    Is this true for PBP ?
    PBP
    XRUN:
    IF (A == B) THEN X = Z
    RUNX:
    IF (A = B) THEN X = Z
    Generated ASM
            LABEL?L	_XRUN
    	CMPNE?BBL	_A, _B, L00001
    	MOVE?BB	_Z, _X
    	LABEL?L	L00001
    	LABEL?L	_RUNX
    	CMPNE?BBL	_A, _B, L00003
    	MOVE?BB	_Z, _X
    	LABEL?L	L00003
    Looks the same to me..
    C != pbp . . . . .
    C != pbp . . . . .
    That will not compile...
    Can not use a comparison operator as a statement....
    Default GeekSpeak
    You're right! it should be
    If C != PBP Then Gosub buy
    Buy:
    Buy PBP
  1. 4 Bytes one button press
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 15th January 2010, 23:36
  2. ISD17240 on PIC16F88
    By drewcog in forum mel PIC BASIC Pro
    Last Post: - 17th December 2008, 21:07
  3. shifting problem
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 31st August 2007, 07:11
  4. Bitwise Operators
    By SterlingY in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 06:57
  5. Bitwise not working
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 19th October 2006, 08:31
