12f675_fuse_about_to_blow!
Results 1 to 40 of 929
    Feb 2010
    I live in the UK
    Have got the night time trigger to send the Visits_total over from the TX to RX working.
    It works on a 555 timer chip instead of an op-amp Schmitt trigger (very handy same voltage for 555 & PIC).The cct dia is below(see attachment). Only needed to add an ORP12 - LDR and a 10k resistor across the input, might have to tweak the resistor value but works a treat with my hand acting as approaching darkness.
    Another step forward.
    COOL!!!!
    Not having seen your code so maybe you have this or considered this...
    It is easy to have false triggers when sensing light, sensing "dark" at dusk could give trouble. You may want to incorporate a timer of some kind not to send the data until you are "sure" it is dark. The dark trigger has to be active for 30 minutes???
    What if there is a bug on the sensor?? A real bug...
    Feb 2010
    I live in the UK
    Hi mackrackit
    Mm, how about sending the PIC back to SLEEP awaiting another Interrupt_On_Change (the birds have started visiting again it was only a cloud) so carry on counting. If after say SLEEP 1800(about half an hour) the LDR is still high then Send_Data it really is dark!
    Oh dear, Badgers I don't mind (even Bears seem kind of cuddly) but bugs!!!
    I think the code would have to be something like:
    IF Count_Input_Pin is HIGH for >50ms THEN SEND:
    SEND:
    'Mrs LEDave  into the garden and clean the sensor.
    RETURN.
    That's an interesting point though because the Birds don't always fly straight into the nest box they quite often hang by the hole then enter so the timing(or lenght of time) of the INPUT COUNTER will need some thinking about.
    I have not been able to program Mrs. Mackrackit. Fuzzy logic
    That should work.
    "Debounce" so one count per bird...
    Feb 2010
    I live in the UK
    Lol, I think we're starting to skate on thin ice here
    That should work.
    I sometimes wonder is there a 'best of practise' when it comes to programming - Then again I'm still pretty much at the 'if it works I'm happy' stage of things......
    Ah, I remember Debounce.
    Right then, onto the sensor input / count.
    Yup, it is called seeing how Darrel or Bruce would do it..
    Me too!
    Feb 2010
    I live in the UK
    Problem:
    I'm using SLEEP uncalibrated to put the PIC to SLEEP until an IOC occurs earlier on in the program. I'm also using SLEEP 1800 to put the PIC to sleep and test that it's still dark before transmitting the VISITS data. I'm getting an error when I compile the program though (see attachment). I've turned the _WDT_ON but still this error. Any ideas? Is using SLEEP an SLEEP Period in the same program uncompatable?
    DARK:
         E_OUT=0           ' Disable transmitter
         INTCON.0 = 0      ' Clear int on change flag
         @ SLEEP 1800      ' It could be night time...It might only be a cloud though...
                           ' so back to sleep for half an hour..zzzz
         @ NOP             ' Do nothing for 1st instruction on wake-up
        if  GPIO.4= 0  then ENCODE  ' It really ia dark so carry on and transmit VISITS
        IF  GPIO.4= 1  THEN RETURN  ' It's not dark after all so carry_on_counting
    Forgot to add, if I comment out the line:
    the program compiles
