12f675_fuse_about_to_blow!
Results 1 to 40 of 929
Threaded View
  1. #33
    Feb 2010
    I live in the UK
    Thanks for that mackrackit.
    I was thinking that the TX will work in a kind of fully automatic mode, no actual button pressing to transmit the days data_count over. The trigger for this would be the LDR sensing it's dark(so no more feeds / visits) turning a pin high that then triggers the transmit.
    This the pin-out as is stands is below:
    GPIO.0 - Pot - R1
    GPIO.1 - Pot - R2
    GPIO.2 - Data_out
    GPIO.3 - SW2
    GPIO.4 - SW1
    GPIO.5 - RF_Enable
    So I'm thinking I need two more input pins (one for the sensor the other for the LDR) Pots R1 - R2 look favourite to me, do you think they'd be ok as inputs.
