Hi mackrackit,
Do you have it set up so one button sends a value and the other button sends a different value?
No, not at present. At the moment either button press will send the value seven (I've made a few code changes), the receiver code then runs the loop and counts / flashes the led seven times.The test is the value sent & received must = 7 or nothing will happen (and it does).....
