12f675_fuse_about_to_blow!
Results 1 to 40 of 929
    That looks about right for that chip. You should have save available though! Maybe you need to have some code in the window for that. Looks like most of the greyed out options are for the in circuit debuger. Some other chips: 16F627(A), 16F628(A), 16F73, 16F74, 16F76, 16F77, 16F870, 16F871, 16F873(A), 16F874(A), 16F876(A), 16F877(A), 16F87, 16F88, 18F242, 18F248, 18F252, 18F258, 18F442, 18F448, 18F452, 18F458, 18F1220, 18F1320, 18F2220, 18F2320, 18F4220, 18F4320, 18F6620 and 18F8620
    have an in circuit debug available for them, but as you can see, they are a bit limited. It is an interesting feature though.
    Walter
    http://www.scalerobotics.com
    Feb 2010
    I live in the UK
    Hi Walter
    Exactly that, I added some code and 'Save' changed from greyed out to Bold.
    That was interesting, I changed the chip from a 12F675 to a 16F627(A) and the RUN-STOP-STEP-PAUSE changed from greyed out to Bold,
    like you said then that must be because the chip has a Debug available to them (I've never used Debug).
    Cheers: Dave
    Quote Originally Posted by LEDave View Post
    Hi Dave,
    Bruce did a great write up on how to use it here: http://www.rentron.com/PicBasic/MCS_X3.htm
    I used to use it, and it is pretty cool. When I needed to try to debug things that were using the serial port already, I had to find other ways to debug (not necessarily better). But I would say it can be pretty helpful when you are starting out.
    The way it debugs is that it adds code into your program to talk back and forth through the serial port. That way it updates registers, etc so you can see them in the ICD. It uses a fair amount of resources, so it slows things down a great deal, but it is fast enough for a lot of projects.
    Feb 2010
    I live in the UK
    Thanks for that Walter and the link, very interesting and something else to look into.
    Feb 2010
    I live in the UK
    We've touched on this before, when I compile Bruce's TX program I get these errors (see attachment). This is because as mackrackit said earlier in the thread:
    Bruce is using PM for an assembler in that example.
    And:
    PM is the assembler from the Pic Basic folks. It works well on the older and smaller chips.
    Also:
    MPASM from MicroChip works for everything.
    So the compiler error is due (I think) to having the wrong type of configuration fuse in Bruce's program (see second attachment) and I need to change them to this type (see third attachment) and it will compile.
    Have I got that right?
    You will want to change these lines in your code
    @ DEVICE PIC12F675,MCLR_OFF,INTRC_OSC_NOCLKOUT,WDT_OFF,BOD_OFF
    @ DEVICE PWRT_ON,PROTECT_OFF
    to
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    when using MPASM as an assembler.
    And comment the *.inc file in the PBP directory.
    http://www.picbasic.co.uk/forum/cont...o-your-Program
    Feb 2010
    I live in the UK
    Hi mackrackit,
    Well I changed the lines of code and compiled the program without commenting the the *.inc file in the PBP directory and the compiler gave the error below(see attachment). I was expecting that as per your Forum link.
    It's the
    that's causing me the problem and I've conFUSED myself big time here. The only .INC files I can find are in this path:C:\Program Files\Microchip\MPASM Suite. I've read the Forum page link you posted up but I still can't see what I need to do.
    Another pointer if poss please.
    LedimDave
