12f675_fuse_about_to_blow!
Results 1 to 40 of 929
    Feb 2010
    I live in the UK
    Give this a shot
    Yep, spot on.
    BTW. I will have limited to none internet till Monday so I may not be around here much in the mean time.
    Ok. Watch out for IWS though (Internet_withdrawl_Syndrom).It starts after about three hours with me, symptoms:Anxiety(have I any emails?)...This news paper isn't in PDF format(worse still it's non tech related)....etc. If left untreated this is a serious condition, only known cures:WIFI mobile phone or a broadband connection, so check you route!
    Have fun!!!
    You too, plenty of reading for me on ADC over the next few days.
    Feb 2010
    I live in the UK
    I bet you thought I'd left the Country the time this one has taken me. I must admit I really confused myself at times and went around in circles a little (ok, a lot).
    Anyway I think I've managed to convert mackrackit's 8bit ADC to a 10bit for the 16F684. I would be very interested to hear how I've done on this one. Seems to work, or have I just 'lucked in'?
      @DEVICE_INTRC_OSC_NOCLKOUT
      @DEVICE_WDT_ON
      @DEVICE_MCLRE_OFF
      @DEVICE_CP_OFF
      ANSEL = %00000001 'CHANNEL AN0
      ADCON1 = %01010000 'FOSC/16
      TRISA = %00000001  'AN0_Input Pin
      CMCON0 = %00000111 'COMPARATORS OFF.
      CHAN0  VAR word   'VAR TO HOLD ADC0N READING (10-BIT)
        CHECK:
        GOSUB ADC_0
        GOSUB BLINK
        GOTO CHECK
        BLINK:
        SELECT CASE CHAN0
               CASE IS > 64
                    TRISA = %11001111
                    PORTA = %00010000
               CASE ELSE
                    PORTA = %00000000
        END SELECT
        ADC_0:       'READ AN0
        ADCON0 = %10000001      'BIT0=ADC ENABLE: BIT1=A/D CONVERSION STATUS BIT
                                'BITS2-4=AN0 CHANNEL SELECT BIT(CHS0): ADFM BIT1= right justified
        GOSUB   READ_AD
        CHAN0.highbyte = ADRESH  'A/D HIGHBYTE
        CHAN0.LOWBYTE  = ADRESL  'A/D LOWBYTE
        READ_AD:   'START THE ADC CONVERSION
        PAUSE 50
        ADCON0.1=1 '1 = A/D conversion cycle in progress.
                   'Setting this bit starts an A/D conversion cycle.
        WHILE ADCON0.1=1:WEND 'Do WHILE condition is TRUE (I like WEND!).
    (I like WEND!)
    Looks like you got it!!!
    Now change the select case to use the ten bit values. 0 to 1023.
    And for you project you may want to play with some averaging. Analog will tend to drift with a temperature flux (resistors) or more so for your application how sensitive you want the LDR (stray car lights?).
    Feb 2010
    I live in the UK
    I changed the value to 1022 and the led lit and occasionally flicked off then back on, so right at the end of the 10bit conversion / pot sensitivity. At a value of 1 the led lit with some pot 'travel' still left. So pretty spot on I'd say:
    Mmm, interesting. I want to transmit the data (days total count) when it's dark and the parents have stopped feeding the young for the day. Like you say though, I don't want say the garden PIR light (when the Badger arrives) to effect things so some averaging and tweaking / testing needed here.
    As ever a big thank you for the 8bit ADC program pointer mackrackit. When it came to doing the 10bit conversion I've learned a lot about setting REGISTER bits, I'm still painfully slow but I guess that will improve with time / practise really interesting learning though.
    Just spotted that this should read ADFM BIT7=1= right justified
    And as for WEND, I suppose elegant would be the word.
    But your code was correct....
    Have you done a FOR/NEXT loop yet?
    Here is a snip from an 8 bit averaging. Pretty simple. Some like to throw out the first and last readings and only use the middle values. I guess it depends on the app..
    GET_T:
      ADC_TEMP = 0
      FOR X_TEMP = 1 TO 20
      ADCON0=00000001
      GOSUB READ_AD
      S_TEMP = ADRESH
      ADC_TEMP = ADC_TEMP + S_TEMP
      PAUSE 250
      NEXT X_TEMP
      OUT_TEMP = ADC_TEMP / 20
    Feb 2010
    I live in the UK
    Here is another way.
    It's not fair you know, Derrel Taylor may have the same initials as me, even the same surname but his brain must be at least twice the size........at least!
    Very clever program (I'll fess up I had to WIKI hysteresis(I had heard of it though)).
    Feb 2010
    I live in the UK
    Yes, your good self and Henrik explained FOR/NEXT loop and LOOKUP when I was using a BCD driver to make a seven segment display count up and down from 0-9 and write my name. Seems like ages ago now, it was only February/March this year
    So your example adds the value S_TEMP to the stored value ADC_TEMP which is done 20 times, then the ADC_TEMP value is output as OUT_TEMP a 20 cycle average (I hope I've read this right).
    Now I'm thinking thermocouple / ADC / Seven segment display.....Another project!
    Ah, before I forget, from your ADC/rentron explanation link you posted earlier. The ADC conversion is displayed on a rather nice data logger display, is this logger included in the Microcode studio package the same as the Serial Communicator? Image below:
