Same problem here with time and now I find out that I am getting sent "out of town" for a couple weeks. Not sure how much I will be online for a while.
Put your Boss on, I'll have a word (unless you're being sent to Hawaii or similar?)Same problem here with time and now I find out that I am getting sent "out of town" for a couple weeks. Not sure how much I will be online for a while.
These things happen from time to time. As the BBC say 'Normal service will resume shortly'.
Have a good trip.
Hi mackrackit,
I hope your working out of Town is going well and not causing you too many problems?
I've been working on the Servo 'Badger' project these last couple of nights (I've actually been able to make some spare time)
The project is coming along well now. The PIR puts a 5V input onto PORTC.3 on the PIC which in turn puts a PULSE onto the servo which then moves up and operates the cable release to start the camera. When I finally finish the whole thing I'll put the code up.
Anyway I hope you're keeping well.
Glad the project is going well. Maybe you can post a picture of a badger soon
Things here went better than expected, now I am back in the shop trying to get caught up on other things... it never ends![]()
I should have it rigged to go for the weekend so fingers X'd.Glad the project is going well. Maybe you can post a picture of a badger soon
I'm still amazed at the versatility of these PIC's though, is there anything they can't do circuit wise?
Pleased it went well, like you say though....it never does endThings here went better than expected, now I am back in the shop trying to get caught up on other things... it never ends
Take it easy.
Well I spent hours writing a program to operate a video camera to film the 'Badger' only to find out that the video camera after five minutes powers down and a switch has to be pushed up to re-activate into record mode and then the record button pressed. So a non starter after all that.
I then hooked out my old but simple digital stills camera and re-wrote the program to activate that.The camera stays 'on' when powered up using the mains adaptorso no power down problem and I've turned the LCD display off.
All I need to do now is make a simple board up for the PIC (It's on breadboard at the moment) and I should be in business tomorrow night.
Probably not the most accurate program ever written, then again I couldn't turn an LED on this Februaryanyway here's the code:
What do you think?Code:ANSEL = %00000000 'Disable analog select so ports work as digital i/o. CMCON0 = %00000111 'Disable analog comparators. TRISA = %00000000 'Set PORTA as OUTPUT. PORTA = %00000000 'Set PORTA pins all low. TRISC = %00001000 'Set PORTC.0 as INPUT. PORTC = %00000000 'Set PORTC pins all low. x var byte 'Loop counter Variable Servo var PORTC.1 'Servo control output_pin PORTC = 0 'Setup for high_pulsout MAIN: PAUSE 50 FOR X = 1 TO 20 PULSOUT Servo,180 'Set the Servo_Arm_Pos (Ready to take a picture) PAUSE 20 NEXT X LOOP1: PAUSE 50 IF PORTC.3 = 0 THEN FIRE: 'PIR Activated (Badger present?)(N/C Contacts opened). IF PORTC.3 = 1 THEN LOOP1:'PIR Not activated loop until it is. FIRE: 'Take a picture routine PAUSE 50 FOR X = 1 TO 20 pulsout servo,130 'Servo_arm moves cable release to take picture PAUSE 50 NEXT X pause 1000 'Time for shutter to fire FOR X = 1 TO 20 'Cable release for camera released / picture taken PULSOUT Servo,180 'Servo_arm moves back releases cable release PAUSE 50 NEXT X PAUSE 10000 'Wait 10 sec's for Camera flash to recycle / recharge goto LOOP1:
Looks like you are coming right along!
But I am curious about one thing...
What do you plan to do when you find out it is a badger?
