12f675_fuse_about_to_blow!
Results 1 to 40 of 929
    Really sorry for the late reply, has been one of those days today.
    Days???
    I have been having one of those weeks
    Feb 2010
    I live in the UK
    Hi mackrackit,
    Lol..... Nice to know I'm not alone, you do have my sympathy though.
    Here's what I thought was a silly question, now I'm not so sure it is:
    When you declare a VAR WORD, I thought that the value would automatically be set at zero, now I'm not so sure it is. Do you have to have to re-set it to zero before you start a count program or is it zero already?
    I know it's Friday tomorrow but I hope your week gets better.
    Sometimes it will be zero at power up but you never know.
    You can use CLEAR, in the manual
    or
    VAR_IN_QUESTION = 0
    Not a stupid question at all
    Feb 2010
    I live in the UK
    Cheers mackrackit, I'm feeling better already I hope you are too!
    So probably good practice to set VAR_IN_QUESTION = 0 just in case.
    Hopefully I'll have moved the program on tomorrow, fingers x'd.
    Right, time for me bed.
    See you tomorrow.
    Hint
    COUNT is for pulses in a time period.
    Maybe
    if switch goes high
    then
    var = var + 1
    Feb 2010
    I live in the UK
    Hi mackrackit,
    Question: How long does it take LEDave to wire a push_button_switch to a PIC16F684?
    Answer: About 48hrs
    I think the program below should work ok:
    Total var word
    clear
    MAIN:
    if PORTA.5 = 0  then  count_up:
    IF PORTA.5 = 1  THEN      MAIN:
    Count_up:
    let Total = Total + 1
    pauseus 25
    LCDOUT $FE,1
    LCDOUT $FE,$C0,DEC Total
    PAUSE 500
    GOTO MAIN:
    LEDave current status: Eyes going, mind boarderline!
    Dvae
    Quote Originally Posted by LEDave View Post
    Total var word
    clear
    MAIN:
    Count_up:
    pauseus 25
    LCDOUT $FE,1
    PAUSE 500
    GOTO MAIN:
    It looks good.
    Dvae
    Hey, that means you have passed the initiation and are a full codder now.
    Feb 2010
    I live in the UK
    So the next thing it to WRITE 'Total' to EEPROM address, then READ that value and put it back into 'Total'.
    The theory is that when the PIC power supply is turned off then restarted last 'Total' reappears on the LCD.
    Yup, that is the mission
    Feb 2010
    I live in the UK
    From the manual:
     WRITE Address,Value
    So looking at the 16F684.PDF it says:
    The PIC16F684 has 256 bytes of data EEPROM
    with an address range from 0h to FFh.
    So would:
    WRITE 0h,Total
    work? Not quite as simple as that he says! For one thing these are EEPROM BYTES and 'Total' is a WORD two BYTES for a starter.
    Dvae
