12f675_fuse_about_to_blow!
Results 1 to 40 of 929
    Feb 2010
    I live in the UK
    Cheers mackrackit,
    Things slowly starting to filter through. I'll have a look tomorrow.
    I love the old LCD though, cracking.
    Dvae
    Feb 2010
    I live in the UK
    Hi mackrackit,
    Well I managed to get the program to do what I wanted it to do, namely run through four custom characters then place the four custom characters one in each corner of the display ( program code below).
    All the info to do this was found within the LCD link you posted However, I can't really see how the CONSTANT:
    Row1  CON 128
    works, what does the 128 part of it mean? I guess it must relate to LCD position HEX 0000 DDRAM Address for a 4 Line LCD but can't relate that to a CGRAM character position.
    ANSEL   = %00000000    'Disable analog select so ports work as digital i/o.
    CMCON0  = %00000111    'Disable analog comparators.
    TRISA   = %00000000    'Set PORTA as OUTPUT.
    PORTA   = %00000000    'Set PORTA pins all low.
    TRISC   = %00000000    'Set PORTC as OUTPUT.
    PORTC   = %00000000    'Set PORTC pins all low.
    DEFINE LCD_DREG     PORTC    'PORTC.0 WILL CONNECT TO DB4, PORTC3 TO DB7
    DEFINE LCD_DBIT     0
    DEFINE LCD_RSREG    PORTC
    DEFINE LCD_RSBIT    4        'PORTC.4 CONNECT TO LCD PIN4
    DEFINE LCD_EREG     PORTC
    DEFINE LCD_EBIT     5        'PORTC.5 CONNECT TO LCD PIN6
    DEFINE LCD_BITS     4
    DEFINE LCD_LINES    4
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 150
    Row1  CON 128
    Row2  CON 192
    Row3  CON 148
    Row4  CON 212
    LCDOUT $FE,$40,$02,$06,$1a,$1a,$1a,$06,$02,$00 'FIRST  CHAR 0 (Battery)
    LCDOUT $FE,$48,$06,$0f,$0f,$0f,$0f,$0f,$0f,$00 'Second CHAR 1 (Speaker)
    lcdout $FE,$50,$1F,$11,$15,$17,$17,$15,$11,$1F 'Third  CHAR 2 (Copywrite)
    lcdout $FE,$58,$00,$0a,$0a,$00,$00,$11,$0e,$00 'Fourth CHAR 3 (Smiley)
    MAIN:
    PAUSE 500
    LCDOUT $FE,1,0 'First character
    LCDOUT $FE,1,1 'Second character
    lcdout $FE,1,2 'Third character
    PAUSE 1000
    lcdout $fe,1,3 'Fourth Character
    LCDOUT $FE,Row1+0,0 'Places CHAR 0 Top LHS of display.
    PAUSE 250
    lcdout $FE,ROW1+19,1 'Places CHAR 1 Top RHS of display.
    PAUSE 250
    LCDOUT $FE,Row4+0,2  'Places CHAR 2 Bottom LHS of display.
    PAUSE 250
    LCDOUT $FE,Row4+19,3 'Places CHAR 3 Bottom RHS of display.
    PAUSE 4000
    GOTO MAIN
    Dave (lovin his LCD).
    Each position on the display has a number for an "address".
    Row1  CON 128 = $80
    Row2  CON 192 = $C0
    Row3  CON 148 = $90
    Row4  CON 212 = $D0
    'All first position on each of the lines
    By adding to the constant you can place the character anyplace you want on the display.
    First line third position from the left would be
    $83 or 131
    Setup a loop adding to the constant and see if you can make something scroll.
    Feb 2010
    I live in the UK
    Ah right (penny drops) cheers mackrackit.
    Mmm, I'll see what I can do.
    Feb 2010
    I live in the UK
    I'm still working hard on this........!
    I know what I need to do to get this to work (on paper as it were, I think I do anyway). I'm reading and GQQGLing like made to find and learn the programming skill I need to make it work.
    If I can't crack it tonight I'll have to ask, tick, tick, tick....must dash.
    Feb 2010
    I live in the UK
    Well I did try.......
    It was getting the LCD to output B0 as a DEC number (LCD location for the smiley) rather than just B0 that foxed me. I tried DEC B0 and a few other things ("."B0..."B0") but still no good. I think (and hope) I was on the right lines though.
    Here's my attempt:
    BO VAR BYTE          'BYTE 0  Sets position for CHAR  128...+19
    LC var byte          'Loop_Count Counts 0 to 19 'positions' across display
    LCDOut $FE,$60,$00,$0a,$0a,$00,$00,$11,$0e,$00  'Smiley Face
    Pause 500
    MAIN
    For LC = 0 TO 19
    PAUSE 500
    LET BO = 128 + LC     'Start at LCD Top LHS then add 1 to move across display
    LCDOUT $FE,1,B0,0     'Output the 'Smiley Face' at location B0
    PAUSE 500
    Next LC
    GOTO MAIN
    Reallllllly close
    Made a couple smal changes
    LCDOut $FE,$40,$00,$0a,$0a,$00,$00,$11,$0e,$00  'Smiley Face
    For LC = 0 TO 19
    PAUSE 500
    LCDOUT $FE,1
    LCDOUT $FE,BO,0     'Output the 'Smiley Face' at location B0
    PAUSE 500
    Next LC
    GOTO MAIN
    But there is still one small problem...
    I will leave that for you
