12f675_fuse_about_to_blow!
Results 1 to 40 of 929
    Feb 2010
    I live in the UK
    Hi mackrackit,
    I run those number variations / combinations, what a difference:
    SERIN2 PORTC.5, 16780,[DEC NUM1, DEC NUM2]
    This one grabbed 123 then added 123 to give 246.
    [DEC2 NUM1, DEC NUM2]
    This one grabbed the 1 and the 2 to give twelve, then added the 3 to give 15.
    [DEC NUM1, DEC2 NUM2]
    This grabbed 123 + 12 to give 135
    Like you said earlier:
    One of the things you need to consider is, how is the data coming into the MCU?
    I can see this is very important, you've got to be comparing apples with apples, or else you're in real trouble, or at least be aware of how the numbers will be affected, your term 'grabbed' was right on the money.
    Looks like you are getting VARIABLE size confused with this.
    Guilty, I do tend to look at things one dimentionally before moving around and taking another view of things. It's that old lack of knowledge thing again
    Ah just remembered, in the PICBASIC PRO book, the DB9 cable dia has a 22k series resistor on PIN3, do I need to add one or am I ok you think? (I can't smell any smoke)
    Where to next......?
    Probably a good idea to use the resistor, on both pins 2 and 3.
    Next... Some flow control.
    What happens if you do not send data? _____________
    There is a TIME OUT/ LABEL thing that goes with SERIN2 just for that.
    Write a sub routine to indicate that data has not been received. Make it short, could be missing data while in the sub routine.
    Feb 2010
    I live in the UK
    Mmm, interesting.....!
    More reading / GQQGLING for me.
    Quick question, we set the mode to 16780 (2400 baud inverted). Does this in tern automatically set the FlowPin to the correct enabled state? 'This enabled state is determined by the polarity of the data specified by mode' (from the manual).
    Also what's a reasonable 'Timeout' period in milliseconds for this?
    I'll pick up a couple of resistors in the morning.
    See you tomorrow.
    Yes, the FLOW PIN is automatically taken care of if used, but we do not need it for what we are doing. It is an option only.
    That depends on the whole setup for what you intend to do. For these test with keyboard/PC entry 500+ might be a good place to start. If you are connected to something like a GPS that continuously sends data and depending on what else the program does 100 may be what works.
    Feb 2010
    I live in the UK
    Quick question. What happens to the value of TOTAL at it's memory location after it's sent serially?
    Does the memory location automatically get reset to zero or does the value TOTAL stay there until over-written
    by the next TOTAL value to be sent?
    SEROUT2 PORTC.3, 16780, [DEC TOTAL, 10, 13]
    It stays until over-written or power down.
    Feb 2010
    I live in the UK
    Hi mackrackit,
    I expect you can hear the cogs grinding from where you are today
    Here's what I'm thinking:
    Timeout con 500
    MAIN:
    PAUSE 250
    SERIN2 PORTC.5, 16780, [WAIT ("#"),DEC NUM1,Timeout,Data_Not_Sent,]
    I've made Timeout a CONSTANT 500. Then the program goes to the LABEL Data_Not_Sent. This is were I'm struggling in that I need to be able to tell if the data has been sent. If TOTAL did reset to zero when data was sent I could have used that but it doesn't and it could have just sent to nought's so that would be no good for a handle anyway. Then I though I could 'read' the PIN PORTC.3 to see if that had changed state, again that's only 50-50 that it has from HO to Low and also it could have just sent two zero's which would show no change.
    So I'm looking for something to show a change or changed state when data is sent (I think).
    Am I hot or cold in that last assumption?
