12f675_fuse_about_to_blow!
Results 1 to 40 of 929
    Quote Originally Posted by LEDave View Post
    As an aside here, is it just me or is there something 'magical' 'mystical' even about all this? You've a little black 'spider' with 14 legs and three wires attached and numbers appearing on a monitor at the press of a button, I love it.
    Kind of like science fiction.
    Feb 2010
    I live in the UK
    Exactly,even stranger though!
    Here's tonight's effort, it works up to DEC255 then ouputs a zero for 256 etc, which is larger than a BYTE I'm thinking.
    ANSEL   = %00000000    'Disable analog select so ports work as digital i/o.
    CMCON0  = %00000111    'Disable analog comparators.
    TRISA   = %00000000    'Set PORTA as OUTPUT.
    PORTA   = %00000000    'Set PORTA pins all low.
    TRISC   = %00000000    'Set PORTC as OUTPUT.
    PORTC   = %00000000    'Set PORTC pins all low.
    MYVAR  VAR BYTE
    MAIN:
    PAUSE 250
    SERIN2 PORTC.5, 16780, [DEC MYVAR] 'MODE 16780 = 2400 BAUD INVERTED
    IF MYVAR = MYVAR THEN HIGH PORTA.5 'LET'S YOU INPUT ANY NUMBER.
    PAUSE 5000
    low PORTA.5
    pause 250
    SEROUT2 PORTC.3, 16780, [HEX MYVAR, 10, 13] 'OUTPUT IN HEX 'MYVAR' 10=L_FEED 13=C_RETURN
    pause 5000
    GOTO MAIN
    Feb 2010
    I live in the UK
    From the second part of the brief:
    Could even send a couple of numbers and have an operation done on them and the results sent back to the PC.
    Hmm, a little stumped here. To my mind (after a lot of reading but obviously not enough!) when the first BYTE (number) arrives I need to send it to a memory location where it won't be overwritten when the second BYTE arrives.Then add the two together.
    The only thing I've found so far that has a seperate address element is this (I think):
     Label VAR Size[Number of elements]
    I'm thinking: MYVAR VAR BYTE [1] which is two elements 0,1. then somehow add element 0 to element1.
    Warm or way off?
    Feb 2010
    I live in the UK
    Now I'm thinking:
    Might be used to output a block of data....Mmm..
    A little more research me thinks.
    Yup, remember when counting not to start at 1 like we were taught in school.
    Always start at the origin... ZERO
    I was thinking along the lines of something like this for now
    NUM1  VAR  BYTE
    NUM2  VAR  BYTE
    I was saving ARRAYs for a little latter
    But if you want to read ahead...
    http://www.picbasic.co.uk/forum/showthread.php?t=544
    Feb 2010
    I live in the UK
    Hi mackrackit
    I'm with you, reading ahead is ok but learn to walk then run (or crawl then walk in my case).
    Just out of interest would the ARRAY idea have worked?
    This code is just an idea, is it on the right lines?
    SERIN2 PORTC.5, 16780, [DEC NUM1] 'MODE 16780 = 2400 BAUD INVERTED
    SERIN2 PORTC.5, 16780, [DEC NUM2] 'MODE 16780 = 2400 BAUD INVERTED
    LET TOTAL = NUM1 + NUM2
    SEROUT2 PORTC.3 TOTAL
    An array can be made to work and so could your code as it is written, but...
    One of the things you need to consider is, how is the data coming into the MCU?
    123
    1,2,3
    12,3
    12M3
    The code on the MCU needs to know what to expect or it is not going to know what to do with the data.
    That is where arrays come in handy, but then you need to figure out what and where the data you want to use is located in the array.
    I know, not a direct answer
    Reread the section of the manual SERIN2 and the WAIT thing. Also find out what DEC2 or DEC3 does.
