12f675_fuse_about_to_blow!
Results 1 to 40 of 929
    Feb 2010
    I live in the UK
    Hi mackrackit,
    The serial data transfer is working a treat
    Before we move on a couple of quick questions I'm a little confused on.
    1/ 16780. This is the MODE for inverted 2400 baud right?
    2/ The 'inverted' baud. Is that just keeping the transmit voltage level from pc - PIC at TTL levels 0 and +5v, instead of + or - 12v as used it RS232?
    Right then what's next (I've got a spare brown wire here just itching to send something out of my PIC)
    Feb 2010
    I live in the UK
    Would this work to send '4' out on PORTC.3 when '3' comes in from the pc.
    ANSEL   = %00000000    'Disable analog select so ports work as digital i/o.
    CMCON0  = %00000111    'Disable analog comparators.
    TRISA   = %00000000    'Set PORTA as OUTPUT.
    PORTA   = %00000000    'Set PORTA pins all low.
    TRISC   = %00000000    'Set PORTC as OUTPUT.
    PORTC   = %00000000    'Set PORTC pins all low.
    MYVAR  VAR BYTE
    DATA_OUT CON 4
    MAIN:
    PAUSE 250
    SERIN2 PORTC.5, 16780, [DEC MYVAR] '2400 INVERTED
    IF MYVAR = 3 THEN HIGH PORTA.5
    PAUSE 5000
    LOW PORTA.5
    PAUSE 250
    SEROUT2 PORTC.3, 16780, [DEC DATA_OUT]
    PAUSE 5000
    GOTO MAIN
    Correct
    Nope, inverted means 1 is 0 and 0 is 1.
    It is still 0 to +5.
    What I can see of your code on my phone it looks like it should work.
    Feb 2010
    I live in the UK
    Smile
    And you were right mackrackit
    '3' came in from the pc and '4' arrived on the pc, brilliant!
    Where to next? send some text?
    You can send some text.
    And.....
    Now would be a good time to play with the SERIN2/SEROUT2 modifiers.
    Data can be formatted several ways, HEX, BIN, DEC, ASC||, STRings...
    Might be something sorta fun... Send a number to the PIC® say in DECimal format and have the PIC® return the number in other formats. Play with every combination you can think of. This should give you an understanding how different number systems work with this system.
    Could even send a couple of numbers and have an operation done on them and the results sent back to the PC.
    Feb 2010
    I live in the UK
    I'm on it.
    Could take a day or two (or three) though. One or two 'holes' to plug in LEDave's knowledge base, bear with me.
    As an aside here, is it just me or is there something 'magical' 'mystical' even about all this? You've a little black 'spider' with 14 legs and three wires attached and numbers appearing on a monitor at the press of a button, I love it.
    Must dash, work, work, work and a lot of reading to do.
    Quote Originally Posted by LEDave View Post
    Kind of like science fiction.
