12f675_fuse_about_to_blow!
Results 1 to 40 of 929
    Feb 2010
    I live in the UK
    The serial and LCD stuff should keep you busy for awhile
    I'm really looking forward to it
    I'll order that kit up and the displays asap.
    Feb 2010
    I live in the UK
    Two LCD's and one DB9 (Female) to DB9 (Female) cable ordered up
    Feb 2010
    I live in the UK
    Well the cables have arrived
    First job, cut it in half and meter the pins out?
    Yup.
    You are looking for wires connected to
    pin 5 = common
    pic 2 = data to PC
    pin 3 = data from PC
    The others you will not need for awhile, flow control type stuff.
    Feb 2010
    I live in the UK
    Hi mackrackit,
    Just to make sure that I'm checking the right pins. Pins 5 - 2 - 3 correspond to this diagram:
    http://hflink.com/interface/DB9_RS232_pinout.gif
    No, that is the male connector.
    The female connector starts with 1 on the right.
    Feb 2010
    I live in the UK
    I'm pleased I asked
    The one on the left then.
    LEDave, also known as 'Mr Windy'
