Absolutely, I don't think I've read anything to do with PIC's that hasn't had a 19 page (minimum) PDF attached.
19 pgs sounds like a delight! The 18F46J50 I've been trying to "figure out" has a 554 pg data sheet.
Nice display B_B, again must have took some setting up?
No, actually they are pretty easy to use. They have onboard processor to do the "hard work", and you just send serial commands and data to it with SEROUT.
It also has a slot for a uSD card (up to 2GB) for photo or video storage.
It even has it's own programming language (4DGL) and can operate as a standalone device without an external processor.
The downside is that they are rather pricey. Mine is an "obsolete" model that I got a pretty good deal on or I probably wouldn't have bought it.
Newer models even have touchscreen capability!
If anyone is curious, here's the info for the display I have. The user manual is at the lower left corner of the page.
http://www.4dsystems.com.au/prod.php?id=2
Here's the code I used to display my avatar and greeting message. The Image is stored on the uSD card.
This is just a snippet from a much larger lump of code that displayed a slide show (about 50 items) with a text description for each.
You may still find a few odd variables and stuff left over from the original chunk of code, but it compiles and works on a 16F726.
Most of the code is just setting up registers and declaring variables and stuff. Once you get to the "main" section there's not much to actually sending data and displaying images already stored on the memory card...
'Test program for displaying photos and text  - 16F726 w/ uLCD-320-PM2
Include "MODEDEFS.BAS"   ' Include Shiftin/out modes
DEFINE OSC 16             ' 16 MHz Osc.
DEFINE HSER_BAUD 38400    ' Set baud rate
DEFINE HSER_RCSTA 90h
DEFINE HSER_TXSTA 24h
DEFINE HSER_SPBRG 25     ' 19200 Baud @ 8MHz, 38400 Baud @ 16MHz
@  __config _CONFIG1, _DEBUG_OFF & _PLL_EN & _BORV_2_5 & _BOR_ON & _CP_OFF & _MCLRE_OFF & _PWRT_EN & _WDT_OFF & _INTOSCIO
@  __config _CONFIG2, _VCAP_RA0
'SETUP SOME PORTS AND REGISTERS-----------------???????????????????????????????????----------------
OSCCON=%00110000    'Set Osc to 16MHz.
TRISA=%00000000    'Set 'em all to outputs
TRISB=%00000010	   'Set portB to all outputs except RB1
TRISC=%10000000    'Set portC to all outputs except RC7
ANSELA=%00000000   ' Set all pins to digital
ANSELB=%00000000   ' Set all pins to digital
ADCON0=%00000000   'ADC off
option_reg.7=0
WPUB=%00000010
'ALIAS PINS----------------------------------------------------
to_LCD          var     PORTC.6   '??????????????????????
from_LCD        var     PORTC.7   '?????????????????????
offbutton       var     PORTB.1   '????????????????????????
'---ALLOCATE VARIABLES----------------------------
textstartX      var     word : textstartX=05                 'starting X position for text
textstart1YH    var     word : textstart1YH=01               'starting Y HIGH positon for text line 1
textstart1YL    var     word : textstart1YL=05               'starting Y LOW positon for text line 1
textstart2YH    var     word : textstart2YH=01               'starting Y HIGH positon for text line 2
textstart2YL    var     word : textstart2YL=35               'starting Y LOW positon for text line 2
photostartX     var     byte : photostartx =22               'starting X position for photo
photostartY     var     BYTE : photostartY = 40              'starting Y position for photo
width           var     byte : width = 200                   'image width
height_H        var     byte : height_H = 0                  'image height high byte
height_L        var     byte : height_L = 200                'image height low byte
addr_H          var     byte : addr_H=$00                    'image address on card HIGH byte
addr_M          var     byte : addr_M=$10                    'image address on card MID byte
addr_L          var     byte : addr_L=$00                    'image address on card LOW byte
'---Font sizes---------------------------------------
fontsize1       var     word : fontsize1=01
fontsize2       var     word : fontsize2=02
fontsize3       var     word : fontsize3=03
'---Predefine a few common colors---------------------------
redH            var     byte  : redH=%11111000
redL            var     byte  : redL=%00000000
greenH          var     BYTE  : greenH=%00000111
greenL          var     byte  : greenL=%11100000
blueH           var     byte  : blueH=%00000000
bluel           var     byte  : bluel=%00011111
yellowH         var     byte  : yellowH=%11111111
yellowL         var     byte  : yellowL=%11100000
magentaH        var     byte  : magentaH=%11111000
magentaL        var     byte  : magentaL=%00011111
cyanH           var     byte  : cyanH=%00000111
cyanL           var     byte  : cyanL=%11111111
orangeH         var     byte  : orangeH=%11111010
orangeL         var     Byte  : orangeL=%11100000
BlackH          var     Byte  : BlackH=%00000000
BlackL          var     Byte  : BlackL=%00000000
Goto main: 'skip the subroutines and JGIG\
'---SUBROUTINE TO SHUT DOWN THE LCD DISPLAY "SAFELY" and end the program. (needs power reset to restart)
shutdown:
    HSEROUT [$59,$03,$00]   'power down command
    pause 250
PAUSE 2000    'Make sure the LCD is awake
Hserout [$42, blackH,blackL] 'background color = black
pause 700
Hserout ["O", 01]  'Opaque text
pause 5
HSEROUT ["S",13,00,10,3,greenH,greenL,1,1,"   BYTE_BUTCHER",$00] 'Put user name at top of screen
HSEROUT [$40,$49,photostartx,00,photostartY,width,height_H,height_L,16,addr_H,addr_M,addr_L]  'grab a photo from the uSD card and display it at the predefined coordinates
pause 200
Hserout ["S",textstartX,textstart1YH,textstart1YL,fontsize2,yellowH,yellowL,2,2, "   Greetings",$00]   'text line 1
pause 20
Hserout ["S",textstartX,textstart2YH,textstart2YL,fontsize3,cyanH,cyanL,1,1, "     PBP users!",$00]   'text line 2
checkbutton:
     if offbutton = 0 then gosub shutdown
    Pause 100
    goto checkbutton
steve
