I can go with that. I liked Henrik's microsecond pauses solution to the INTERRUPT PAUSE problem, which is what your'e saying / reiterating.If you need to pause for a long time setup a pause loop with several short pauses to total the time. Get into that habit and when you do need to use an interrupt you will be ready.
Regarding the cable, this isn't what I'm looking for is it? It's the other that needs to be a 'male' connecter is that right?
http://www.maplin.co.uk/module.aspx?moduleno=29968
