12f675_fuse_about_to_blow!
Results 1 to 40 of 929
    Feb 2010
    I live in the UK
    Henrik first of all a big thank you for giving your time to help me along (and everyone else too of course).
    If there's still "basic" stuff that you don't understand then you need to back up and get that sorted first or you will just be creating more problems for yourself. Perhaps we jumped to the LOOKUP and COUNT commands etc a little too soon(?).
    I agree, I do need to back up and go over some of the basics we've covered, like you say running before you can walk with programming will only compound problems later on.
    I think I need to write lots of short programs using the basics and do enough of them to really drive it home.
    That said, I do understand the basic principle of the COUNT command and it's timing component also with the LOOKUP command.
    When you think that trying to use C and assembler I hadn't even managed to switch an LED on! I've come a long since joining this forum and using PB in the last few weeks thanks to you all, there's absolutely no doubt that this in the language to use!
    So no, time to build this circuit (I need to make something work) and I'm sure I'll still have plenty of questions for you about the basics still, so you're not of the hook quite yet....;-)
    David
    No problems, we're all here to help.
    Feb 2010
    I live in the UK
    Hi everyone.
    I haven't posted for a wee while but have been busy reading and building my first two circuits.
    The first is a 12F683 driving four LED's in a binary pattern 0-9 as per the thread (I've also added a nice little Night_Rider effect). I must say, although simple in what I've achieved, when those four LED's run up that binary pattern it was a real thrill, amazing.
    The second circuit marrying the binary counting PIC to the BCD decoder driver then seven segment display is about half way built ( I'm quietly confident about this one fingers x'd).
    Once again, thanks for all your help on here. I really wouldn't have got this far without it.
    I'll be back when the second circuit is completed (early part of next week).
    Hope you're all keeping well.
    David
    Feb 2010
    I live in the UK
    Default Update
    Hi Everyone.
    Just to let you know I've got a a working circuit!!!!! Yippee.
    It's a 12F683 into a SN74LS47N display driver and a 1" seven segment display counting up to nine.The PIC output also switches four transistors with collector LED's for a binary output count as well.
    Simple stuff for you boys I'm sure but I'm chuffed to bits right now.
    Not sure where to go or what to do next (any ideas welcome).
    Thanks for your help as ever.
    COOL!!!! You are moving right along.
    Here is an idea. Setup a hardware timmer to change the display once per second.
    Feb 2010
    I live in the UK
    Hi mackrackit
    Are we saying for example to use the trimmer pot on the PICkit1 to alter the display speed ADC? (ADCIN).
    I'm seriously considering buying the the full program version by the way (I'm just trying to convince myself I'm clever enough to figure out how to use / make the most of it...lol).
    Really enjoying it though (headaches aside ;-))
    No, not trimmer... or timmer .... I really need to get a dictionary
    Timer as in TMRO.
    Many times we will at the beginning of a new project to make sure things are setup correctly we will do a simple "blinky" just like we tell the newbees to do. I will a lot of times leave it running as a "heart beat" type of thing. But if you do this using pauses to blink the LED the pauses will maybe get in the way.
    So now comes a basic interrupt based on time.
    This may or may not be correct for your chip so verify with the data sheet.
        INTCON.5 = 1    'ENABLE TMR0
        OPTION_REG = %10000101  '16BIT 1:64 PRESCALE
        ON INTERRUPT GOTO TLOOP
        MAINLOOP:
        'MAIN CODE GOES HERE
        GOTO MAINLOOP
        DISABLE
        TLOOP:
        INTCON.2=0:TOGGLE PORTD.4
        RESUME: ENABLE
