12f675_fuse_about_to_blow!
Results 1 to 40 of 929
Threaded View
  1. #26
    Yup, I will help.
    Problem is, I can not find a "large" PIC that will work with the demo and the PICkit1. (14 pins)
    So LEDDave may have to get a 16F676 and one of us build the hex for that...
    I know nothing about the PICKit1, can you use ICSP with it ?
    OK I just looked at AN258 http://www.microchip.com/stellent/id...pnote=en012103
    and it clearly shows PICKit1 using ICSP so he can go OFF BOARD with some jumper wires and program chips.
    So is it that the PICKit1 firmware does not support bigger chips ?
    This will work, until he get's serious. http://cgi.ebay.com/Microchip-PIC-JD...item1e595bbf81
    Probably Won't do 18Fs but will do nearly all 16F & 12F series.
