12f675_fuse_about_to_blow!
Results 1 to 40 of 929
Threaded View
  1. #33
    Default Re: 12f675_fuse_about_to_blow!
    Quote Originally Posted by LEDave View Post
    Attachment 5485
    Hi Joe, from the data sheet (pasted above) so yes IOC on pins I need.
    I've changed BAUD to:
    BAUD = 16780        ' Set baud rate here
    Program does same as before though - Also if @SLEEP is commented out as
    mackrackit suggested earlier, the rfpic transmits pretty much transmits on button press.
    I'll have a look into DT_INTS later today, thanks for the pointer.
    PS: Sorry for pasting Data sheet info into the thread instead of as an attachment, not sure what I did wrong there.
    OK, now at home I see why it would work Baud = n2400, because n2400 is set as a symbol in modedefs.bas as 4 (mode 4 ) so its a variable aliasing a constant. Explains Why it Should work. 16780 is a serout2 mode . . . does it work with serout ?
    Edit:
    Oh My Bad, you are using serout2.
